I am designing an IGBT based chopper with single Low side switching IGBT (chosen low side switching because ease of driving the IGBT.)
There are plenty of resources available for SMPS (buck, boost, buck-boost,) PFC chopper, inverters, welding power sources, UPS and motor control applications. I presume all those applications work under duty cycles up to 50% and for motor applications it may go up to 95% (only during the peak of the SPWM signal) but none of the applications mentioned made it to work continuously in the duty cycle range of 90% or above.
I googled a lot and read the application notes, datasheets and reference designs of various IGBT/MOSFET manufacturers such as Infineon, ST, Semikron, Vishay, ROHM, Fuji, Mitubhishi, Hitachi, Toshiba, IXYS, ABB, Renesas, TI, NXP, Nexperia.
Some of the applications listed below which uses IGBT close to 100% duty cycle operation.
  1. HVDC circuit breaker uses a hybrid approach. During operation the current will always flow through the bypass branch which has a mechanical circuit breaker and during the interruption of the current it will be allowed to pass through the IGBT, this application doesn’t help me to understand about the 100% operation of the IGBT.
  2. Another application which uses the duty cycle up to 100% is separately excited DC motor which can use IGBT, but I couldn’t find any reference for the implementation using IGBT and there are plenty of resources available for thyristor based choppers and simulation of the same.
  3. The DC electronic load which uses the MOSFET in DC operation and couldn’t find reference for high power electronics load using IGBT. Many of the manufacturers of IGBT mentioned not to operate the devices in the linear region.
I am intending to use IGBT modules of 1200V/400A (semikron SKM400GB125D half bridge module.) For the proof of concept I used discrete IGBT (IRFGP50B60PD) and drove it up to dutycycle of 50% @ 490Hz and it worked perfectly. The high power IGBT modules the manufacturer doesn’t provide FBSOA but they provide RBSOA and SCSOA details alone. For the short overload conditions recommend to refer the transient thermal impedance characteristics and for the steady state pulsing operations recommends to look at RthJ-C of IGBT & diode.
Many manufacturers have simulators which allows to simulate the electrical and thermal details of our circuit, but for which I couldn’t get some pointers regarding how far the simulation and bench test correlates (correlation of simulation Vs implementation) Semikron Semisel, Infineon (uses PLECS,) Fuji electric. By the simulator, we can estimate the losses of the switch (switching loss and conduction loss) and junction temperatures.
For the following questions I am expecting some inputs from the community:
  1. Is it possible to operate IGBT up to 100% duty cycle? I couldn’t find many application references for IGBTs, which works in the duty cycle close to 100%. The question is similar to https://www.researchgate.net/post/Can_the_IGBT_MOSFET_turn_on_all_time_long_just_as_a_diode
  2. Need some information regarding how far the simulation and bench test correlates (correlation of simulation Vs implementation.)
  3. Reference designs or some resources for DC chopper using IGBT/MOSFET.
  4. Suggest me some technical forum and resources dedicated to power electronics.
    \$\begingroup\$ You need to take a step back and think what "using XYZ at 100% duty cycle" actually means. When will the device be on and when will it be off? Is it possible to operate IGBT up to 100% duty cycle? If I would answer No then I'm saying that I cannot switch this IGBT on for 100% of the time that I am using it. Does that make sense? If (almost) no power is dissipated in the IGBT, what prevents me from keeping it switched on all the time?... \$\endgroup\$ Sep 11, 2019 at 8:25
  • \$\begingroup\$ ...Maybe your application causes the device to heat up when it is on due to a large current. Then you make sure that that is not an issue, the fact that the IGBT will be at 100% duty cycle is irrelevant. What is relevant is maximum continuous current, continuous power dissipation and keeping the IGBT's temperature low enough (use a heatsink). For the other points: you need to do more research on your own and also understand what you're doing. Regarding simulations: depending on how YOU use it you can get completely inaccurate or very accurate results. \$\endgroup\$ Sep 11, 2019 at 8:26
    \$\begingroup\$ Can your unspecified low side driver output 15V V_GE continously? \$\endgroup\$
    – Turbo J
    Sep 11, 2019 at 8:32
    \$\begingroup\$ There is absolutely no problem turning on an IGBT continuously. Why wouldn't it work? Just make sure it does not overheat. \$\endgroup\$
    – user57037
    Sep 13, 2019 at 18:03
    \$\begingroup\$ Simulation is good. It can save a lot of time. If you find that inability to simulate is COSTING YOU TIME, then consider if it makes sense to build and test instead. Empiricism is an integral part of science. It is not as many nowadays seem to believe, inferior to simulation and analysis. Rather, empiricism, simulation and analysis all have to exist together and be given their due. \$\endgroup\$
    – user57037
    Sep 13, 2019 at 18:51
8
Provided you respect its safe operating area and thermal limitations, the IGBT itself will have no trouble with 100% duty cycle.
The gate driver will need some attention. Some types of gate drive circuits or ICs aren't going to be compatible with 100% duty cycle, e.g. those using gate drive transformers or certain types of "bootstrap" power supply. But building or selecting a suitable gate driver for 100% duty operation is not inherently a difficult task, and you were right to make it easier by putting the IGBT on the low side of the load.
  • \$\begingroup\$ For discrete IGBT manufacturer publish and recommend to use SOA, but for High power IGBT modules SOA isn't available. I got confirmation from infineon and Semikron about the non availability of FBSOA for module products. \$\endgroup\$
    – yogece
    Sep 11, 2019 at 12:23
    \$\begingroup\$ Keep it out of the linear region then, and just use load current, Vce(sat) and Rjc \$\endgroup\$ Sep 11, 2019 at 16:24
  • \$\begingroup\$ @pericynthion Especially with these ultra fast ones you never want it to hesitate in the saturation region. Also see this excellent document. semikron provides. Also the last steps leading to 100% might need to be skipped as they might put it in saturation accidentally. \$\endgroup\$
    – Jeroen3
    Sep 13, 2019 at 19:39
  • \$\begingroup\$ @Jeroen3 do you mean the desaturation region? \$\endgroup\$ Sep 13, 2019 at 20:38
Some practical considerations:
  1. In a switching converter, you may have a minimum off time (e.g., half bridge which has deadtime requirements). This, in conjunction with switching frequency, can limit duty cycle to a practical maximum near but less than 100%.
  2. Some converter topologies/control mechanisms have stability limitations that require/warrant staying below 50% duty cycle (e.g., peak current controlled flyback/similar as discussed in http://www.ti.com/lit/an/snva555/snva555.pdf)
  3. Some gate drivers may not be able to operate at 100% duty cycle (e.g., if using a bootstrap capacitor in a high-side gate driver, the cap will eventually bleed down to 0V).
You can generally run an IGBT continuously within its safe operating area - review voltage, current, and thermal ratings. If the load in your circuit is resistive, that would be fairly straightforward so long as switching speed and L*di/dt's are considered.
If you are going to run your IGBT at much lower switching frequencies and have real reliability concerns, I'd also look at thermal cycling considerations.
