A linear regulator is attempted using discrete components as shown below. What is the output voltage ? (Where Voltmeter is connected) Assume Ideal BJTs and MOSFET .
put on hold as off-topic by brhans, Enric Blanco, Transistor, Peter Smith, Hearth Sep 12 at 13:20
  • This question does not appear to be about electronics design within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
    \$\begingroup\$ What have you tried to solve the assignment? Where are you stuck? \$\endgroup\$ – JRE Sep 12 at 11:18
    \$\begingroup\$ Welcome to EE.SE - when we are presented with what appear to be homework questions (we are just getting into prime season for that) then we want to see an attempt to solve; otherwise the question will usually be put on hold and ultimately closed. \$\endgroup\$ – Peter Smith Sep 12 at 11:20
  • \$\begingroup\$ usually a linear regulator needs to operate the comparison-circuit, here the 2-transistor differential-pair, as a linear amplifier; can you show the region of operation for this differential-pair? for example, what is the voltage of the shared-emitters node? \$\endgroup\$ – analogsystemsrf Sep 12 at 11:34
  • 5
    \$\begingroup\$ I'm voting to close this question as off-topic because it looks like homework with no attempt shown. \$\endgroup\$ – brhans Sep 12 at 11:35
  • \$\begingroup\$ The transistor parameter is not given \$\endgroup\$ – Nilabja Saha Sep 12 at 11:54
