I'm reading through the datasheet of the TPA311x family. I'm looking for the input range for pins INPR and INPL but I cannot find this information. I see the absolute maximum ratings, but it's not what I need. I'm interested in the maximum recommended input range for the audio signal.
I also measure an offset of about 2.90V on those pins, but in the ds I can't find this value neither.
If it's not declared, is it safe to use all the available swing, i.e. 2.90V ±2.90V? It means the input signal might swing from 0.00V to 5.80V.
The DS states the pins are biased at 3 volts (page 2).
You take the gain value (programmed at power up) and reverse back from the preferred maximum peak-to-peak output voltage (supply dependent and dictated by your preferred worst case distortion levels) to get the required peak-to-peak input signal.
  • \$\begingroup\$ Ok, it's hidden in the description of the pins at page 4, indeed. I was looking in the specification tables. Got the right procedure to calculate the input range. Thanks. \$\endgroup\$ – Mark Sep 12 at 12:34
