The bode plot of the loop is as shown here
Bode Plots
The transient step response looks like this
Transient Response
The block diagram looks something like this - Basically a single stage opamp(OPAMP in fig) with high gain(cascode structure) biasing a fet(M1) such that its drain is equal to Vbias. Small signal step is applied at I1 Ibias and transient current through the fet M1 drain is observed. Block Diagram
Am I missing something here?
  • \$\begingroup\$ What kind of system are we dealing with? Is it completely linear over the operating range? \$\endgroup\$
    – John D
    Sep 12 '19 at 20:30
  • \$\begingroup\$ It’s a second order system with an opamp in it. Used some miller compensation to split poles apart. When a step current is applied at a point in the loop, I’m observing an overshoot inspite of PM being close to 90 degrees \$\endgroup\$
    – SBO
    Sep 12 '19 at 21:06
  • \$\begingroup\$ Show your circuit? It certainly seems like it should settle nicely. \$\endgroup\$
    – TimWescott
    Sep 12 '19 at 21:58
  • \$\begingroup\$ Also would be good to show how you're measuring the open loop response. How you're "breaking" the loop, injecting the disturbance and where you're measuring the response. \$\endgroup\$
    – John D
    Sep 12 '19 at 22:09
    \$\begingroup\$ It doesn't look to me like your loop gain measurement technique is accounting for the FET's gain. \$\endgroup\$
    Sep 13 '19 at 7:06
I suspect you're looking at an artifact of the propagation delay through the op amp. The output overshoots because the effects of the negative feedback aren't felt until a finite time period after the response to the step.
If there's a propagation delay of N ns, the step response won't produce an effect on the output until T=N, and thus the feedback won't produce an effect until T=2N.
    \$\begingroup\$ Surely, loop analysis characterizes precisely all of that..? \$\endgroup\$
    – Adil Malik
    Sep 13 '19 at 14:38
  • \$\begingroup\$ @AdilMalik - No, loop analysis essentially looks at the response to a CW sine wave after all perturbations have died out. You are looking at a step response, where the effects of the higher-frequency non-linearities are still in force. \$\endgroup\$ Sep 13 '19 at 17:32
    \$\begingroup\$ Yes ofcourse. I agree that frequency response is done on a linearised model. However, this is not what this answer is about and what I am questioning. Christobol refers to delay thru the opamp which should be characterised in the linear model etc? \$\endgroup\$
    – Adil Malik
    Sep 13 '19 at 18:28
This site is temporarily in read only mode and not accepting new answers.
Not the answer you're looking for? Browse other questions tagged .
