I am using Altium 17 and try to make a GND pour. On the GND polygon I want to place some vias to GND polygon. But it doesn't connect GND polygon and GND vias. They belong to exactly same net, GND.
I restarted Altium, but still no success.
GND Pour
GND VIA Properties
  • \$\begingroup\$ Is there any other polygon (even a shelved one) covering the same area? \$\endgroup\$
    – The Photon
    Sep 12, 2019 at 21:29
  • \$\begingroup\$ If you can access Altium forums, check here: AD15 polygon pour bug \$\endgroup\$
    – The Photon
    Sep 12, 2019 at 21:34
  • \$\begingroup\$ Perhaps check your Polygon Connect Style (rules) for either, "Direct connect" or "Relief Connect". \$\endgroup\$
    – Steve
    Sep 12, 2019 at 21:35
  • \$\begingroup\$ There is no other polygon. I deliberately deleted all polygons and tried a small polygon. \$\endgroup\$ Sep 12, 2019 at 21:38
    \$\begingroup\$ I just noticed your "via" isn't a via (as defined by Altium), it's a free pad. Do you get the same result if you place a via rather than a pad? Are your polygon connection rules the same for pads and vias? \$\endgroup\$
    – The Photon
    Sep 12, 2019 at 23:27
Ok I will answer my question. It seems to be a bug in software. I restarted only once and the problem was still there. I deleted the polygon and restarted Altium again. It worked.
Thanks for all answers and suggestions.
Pad and via
Your via is shown as "GND GND". It should just say GND. Possibly there is something wrong with the via net assignment. Have a look at the net in the properties.
Edit: Shown with free pad
    \$\begingroup\$ The "via" isn't a via, it's a free pad. I'm not sure how that would change anything, but... \$\endgroup\$
    – The Photon
    Sep 12, 2019 at 23:28
  • \$\begingroup\$ Ah so- the free pad should have a designator associated with it. Altium should not be confused by a designator of GND but maybe it is? Worth trying changing it anyway. \$\endgroup\$ Sep 12, 2019 at 23:30
  • \$\begingroup\$ Pad or Via, it was the same problem. Designator was also not problem. I don't know the problem was, but i restarted Altium again and it worked! \$\endgroup\$ Sep 13, 2019 at 6:52
