Note: I using quartus ii v13 with vhdl 2008
I am trying to access the current state of my state machine from inside my test bench file. From my understanding I should be able to do this with External Names, however, I keep getting a syntax error "near text "<"; expecting an identifier, or string literal"
GFI_entity.vhd
library ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
USE ieee.std_logic_arith.all;
USE ieee.std_logic_unsigned.all;
entity GFI_entity is
port (
CLK : in std_logic;
my_input1 : in std_logic;
my_input2 : in std_logic;
RST : in std_logic;
my_output1 : out std_logic;
my_output2 : out std_logic;
my_output3 : out std_logic
end GFI_entity;
architecture rtl of GFI_entity is
constant C_2SEC_TC : integer := 127; -- Set this based on clock speed to get desired time
type machineState is (state1, state2, state3, state4, state5, state6, off_state);
signal currentState, nextstate : MachineState;
signal tmr_cnt : std_logic_vector(6 downto 0); -- time counter
signal tc_2sec : std_logic := '0'; -- Indicates counter has reached desired time
signal rst_flag : std_logic := '0'; -- Disables RST if test pulse was successful
signal tmr_exp : std_logic := '0'; -- Latches state of tc_2sec
alias myalias is <<signal .GFI_entity_tb.GFI_entity.currentstate : machinestate>>;
begin
-- synchronous process for the state machine
sm_sync_proc: process(CLK, RST, rst_flag, tmr_exp)
begin
-- condition for RST to not cause a reset if test was successful or timer expired
if((rst_flag = '1' or tmr_exp = '1') and RST = '0') then
currentstate <= off_state;
elsif(RST = '0' and tmr_exp = '0') then
currentState <= state1;
elsif(rising_edge(CLK)) then
currentState <= nextstate;
end if;
end process sm_sync_proc;
cominationLogic: process(currentState, nextstate, my_input1, my_input2, tc_2sec, RST, rst_flag)
begin
case currentState is
-- Wait for charge up time of all inputs
when state1 =>
GFI_entity._tb.vhd
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
use ieee.numeric_std.all;
use IEEE.std_logic_unsigned.all;
ENTITY GFI_entity_tb IS
END GFI_entity_tb;
ARCHITECTURE behavior OF GFI_entity_tb IS
-- Component Declaration for the Unit Under Test (UUT)
COMPONENT GFI_entity
PORT( my_input1 : in std_logic;
RST : in std_logic;
clk : in std_logic;
END COMPONENT;
--Inputs
signal my_input1 : std_logic := '0';
signal my_input2 : std_logic := '0';
signal RST : std_logic := '0';
signal clk : std_logic := '0';
--Outputs
signal my_output1 : std_logic;
signal my_output2 : std_logic;
signal my_output3 : std_logic;
signal count : std_logic_vector(2 downto 0) := "000";
--Clock for testing
constant clk_period : time := 2 ms; -- 500Hz
BEGIN
-- Instantiate the Unit Under Test (UUT)
uut: GFI_entity PORT MAP (
my_input1 => my_input1,
my_input2 => my_input2,
RST => RST,
clk => clk,
my_output1 => my_output1,
my_output2 => my_output2,
my_output3 => my_output3
Clk_process: process
begin
clk <= '1';
wait for clk_period/2;
clk <= '0';
end process;
-- Stimulus process
stim_proc: process
begin
*do testing here*
How can I correctly use External Names here to access my currentstate signal?
The purpose of me wanting to do this is that in my test bench I want to be able to test all possible input conditions at each state, for all my states.
Say im in state2 of my test bench and I want to test a certain input, say input1 = 0 input2 = 1 RST = 0, my state machine should change states. After it does I want to "reset" my current state to be my previous state, state2, so that I can check other possible inputs for state2.
I plan for my test bench to just be a for loop from input1 = 0 input2 = 0 RST = 0 to input1 = 1 input2 = 1 RST = 1, after each iteration of the for loop wait for it to change states, "reset" the current state, and do this 8 times for each state. So that if I have 8 states and 3 inputs it will have tested 64 different combinations. Simply put, I want to test all possible cases.
Maybe theres an easier way to do this? This is my first test bench I've done.
Thanks!
