I want to create an ENABLE signal driving a Murata OKI-T/3-W32P-C DC-DC converter, where the P stands for Positive Polarity of the On/Off Control line: the line has an internal pull-up, which means that the converter is on when the Control line is open or high, and off when pulled to GND.
So what I have right now is a DISABLE signal, based on an N-channel enhancement-type MOSFET (2N7000). initial schema
From what I read online, the easiest way to turn this setup into an ENABLE signal would be to use a depletion-type MOSFET, but I understand that these are rarely used? Or are there depletion-type MOSFETs that are generally recommended just like 2N7000 and other general-purpose transistors?
If not, what would be the right way to go here? connecting the DISABLE signal to Vin using a pull-up resistor, and add another transistor at the low side to pull down the DISABLE signal when the ENABLE signal is activated?
Follow-up:
So here's the adjusted schema following @peufeu solution (thanks for providing a complete solution + explanation): adjusted schema
Which leaves me with the question whether this is the general way to go, or whether the MOSFET-based solution can/should be used when Vin is not as high as 32V:
In the datasheet for this OKI-T/3-W32P-C module I see that there is simply a switch symbol. But in the datasheet for the ABB ABXS002A3X41-SRZ module (fig. 27 on page 11), for example, there is a N-channel/enhanced MOSFET in the circuit. Is that because the max Vin in this case is only 16V? which means that a 2N7000 could be used directly here, as its max Vgs is 20V continuous? ABB ABXS002A3X41-SRZ ENABLE setup
Similar thing in the datasheet for the Murata OKL-T/6-W12 module: Fig. 7 on page 15 shows the P-channel/depletion setup (for a module with negative logic) that I initially thought I could use. This module has a max Vin of 14V, so in this case a MOSFET would be able to handle it without level shifting? And if so, what transistor would be a good candidate? Murata OKL-T/6-W12 ENABLE setup
  • \$\begingroup\$ adjusted the title, as my initial setup was wrong \$\endgroup\$ – Adrian Sep 14 '19 at 18:11
  • \$\begingroup\$ I've edited my answer to reply to your edits \$\endgroup\$ – peufeu Sep 15 '19 at 14:10
Quick datasheet check...
It does not use standard logic levels: "Low" is below 1.2V, and "High" is above Vin-2.5V.
So, level shifting is required if you intend to use standard logic levels (like 3.3V CMOS) to control it.
A depletion N-Channel MOSFET has a negative threshold voltage, it is ON with Vgs=0V. However, it is still N-Channel, which means in order to turn it OFF, you need Vgs to be below the threshold, which means a negative Vgs. I don't think this is what you want, if your control signal is standard logic, it will be positive.
So the simplest solution is to use 2 transistors to invert the signal twice and level-shift it. They can be bipolar or FET. Since the datasheet specifies an iternal pullup on your DC-DC it would be like this:
I used BJTs because your 32V max input voltage will blow the gate of most FETs, so they would need extra components to limit Vgs. I added a pulldown on the input too. This is not necessary if the input is connected directly to a logic circuit, but if it is a connector it is better to have a pulldown to avoid spurious turn-on if a foreign object (ie, a finger) injects some tiny current into the base of the transistor...
In the ABB case fig 27: FET gate is connected to ENABLE signal you provide -- thus you must pick a FET that is compatible with the logic levels of your ENABLE signal, it must fully turn ON on a logic high (5V or 3V3 etc). In this case it is up to the circuit that generates ENABLE signal to ensure Vgs will not exceed 20V. If it comes from a logic circuit, or a switch from the 16V supply, no problem.
The schematic shows a weird MOSFET symbol with incorrect connections and a short between base and emitter of bipolar transistor Q3... ie, this schematic is most likely wrong, don't look at it, follow the instructions in the text instead!
| improve this answer | |
