Components
  • Battery (7.5V 6A Max)
  • D24V25F5 (5V 2.5A step down)
  • U3V50F12 (12V 5A step up)
  • Raspberry Pi 3 (5V 2.1A-2.5A)
  • Motor (12V 3A stall) (Using H-Bridge)
Would the setup be suitable? I much prefer to use one battery instead of two batteries in which one battery runs to each of the voltage regulators. Below I have included a drawing of how I'm going to solder them onto a prototyping PCB.
Do the math on your power budget:
  • The Pi needs up to 2.5 A @ 5 V = 12.5 W
  • The motor needs up to 3.0 A @ 12 V = 36 W
That's a total of 48.5 W
Taking the efficiency of the converters into account, which is going to be 90% or less, that becomes at least \$\frac{48.5 \text{ W}}{0.90} = 53.9 \text{ W}\$ that you need from the battery.
But you say that the battery can only supply 6 A @ 7.5 V = 45 W.
This will work only if you can tolerate overloading the battery each time the motor starts or stalls. (Motors generally pull their stall current when starting from a dead stop.)
And just to clear up the misconception in the title, the regulators are in parallel, not in series.
  • \$\begingroup\$ I think it should be added that there is nothing wrong at all with the concept of connecting a battery up to multiple voltage regulators, it's just that in this particular case the power doesn't work out. \$\endgroup\$ – Hearth Sep 14 '19 at 19:09
  • \$\begingroup\$ Yeah. I forgot to account for the efficiency of the conversion. \$\endgroup\$ – parkcandy Sep 15 '19 at 6:17
