I used a TTP223 IC operating on 5 V. I use the touch IC output (when high) to turn on the LED and (when low) to dim the LED. The LED is operated by the external 5 V. It uses only the touch IC output as a signal. I used a blue LED. What is the problem?
It works fine when turned on, but after several days the touch output hangs.
