after finishing my prototype PCB I am now tasked to fit it inside a machine with almost no space. The PCB is not the problem but the Wire-to-board connectors.
After intensive search I was very overwhelmed of the selection. I narrowed it down to the JST-PH (horizontal 4.6mm) and the Molex DuraClik (6.4mm).
Do any of you know a flatter design, or an alternative?
  • \$\begingroup\$ Use flat cable ones. They can be down to 1.5mm tall \$\endgroup\$ – P__J__ Sep 16 at 7:56
  • \$\begingroup\$ I did not think about flat ribbons. I will look into that \$\endgroup\$ – v3xX Sep 16 at 8:02
  • \$\begingroup\$ If you want to use wires, check the JST SH connector, with a height of 2.9 mm. The Molex PicoBlade system is closely following with 3.4 mm \$\endgroup\$ – Huisman Sep 16 at 8:13
  • \$\begingroup\$ Please note that questions seeking recommendations for specific products or places to purchase them are regarded off-topic as they are r̶a̶r̶e̶l̶y̶ ̶u̶s̶e̶f̶u̶l̶ ̶t̶o̶ ̶o̶t̶h̶e̶r̶s̶ ̶a̶n̶d̶ quickly obsolete. (I definitely find this topic useful, but it will be(come) obsolete; my previous remark is from a research done 4 years ago and therefore outdated) \$\endgroup\$ – Huisman Sep 16 at 8:19
  • \$\begingroup\$ You can also consider FPC flex cable and a ZIF socket <1mm \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Sep 16 at 17:40
