I have created a footprint for an SMA-Connector like this: SMA-Connector
The footprint looks like this:
SMA-Connector Footprint
There are 3 SMD-Pads on the Bottom Layer and 2 SMD-Pads on the Top. The SMDs on the outside overlap with each other but are on different layers, yet when I add it to a board-design and running the DRC, I get one error for each side, stating that there is an overlap. Error Message
Is it not possible to put an SMD at the same position on the top as well as the bottom layer? I thank you all in advance for the help and hope I made my problem clear.
  • \$\begingroup\$ There is a big short on the top layer. \$\endgroup\$ – Jeroen3 Sep 16 '19 at 9:45
  • \$\begingroup\$ Could you be a bit more specific? \$\endgroup\$ – rohulla Sep 16 '19 at 10:13
    \$\begingroup\$ The big red polygon overlaps the smaller red pads. I don't see how to I can any more specific. \$\endgroup\$ – Jeroen3 Sep 16 '19 at 10:58
  • \$\begingroup\$ Alles klar, der Fehler ist behoben, vielen Dank für die rasche Hilfe \$\endgroup\$ – rohulla Sep 16 '19 at 11:47
  • \$\begingroup\$ I don't think it is complaining about overlap with the top/bottom layers, it looks like it is concerned that your pads on the same layer are touching. Instead of using different pads on the top/bottom to achieve the shape, you should use custom shaped pads instead. You also shouldn't be defining a pad that is the shape of the non-pad part that doesn't touch the board. Use an outline for that. \$\endgroup\$ – Ron Beyer Sep 16 '19 at 12:30
