Installed in the Acer Aspire 2920 notebook. Does not work at all - pushing at any angle has no effect. Second button (left touchpad one) works properly.
Circuit diagram lists SW-TACT-119-GP / 62.40009.671. Can not find anything using these numbers other than various Wistron circuit diagrams.
Dimensions are (approximately) 6 * 6 * 3 (mm).
Update:
After taking the closeup pictures I thought that according to the construction the buttons seem to be maintainable. I disassembled all of them - without desoldering the device (only desoldering the top metallic cover's pin), cleaned, assembled back, and now all the buttons function properly.
    \$\begingroup\$ need exact dimensions of the foot print, the part number listed is an internal company part number \$\endgroup\$ – Voltage Spike Sep 17 at 16:33
  • \$\begingroup\$ Updated question, thank you. \$\endgroup\$ – Anonymous Sep 17 at 16:38
  • \$\begingroup\$ Exact dimensions on SMT parts need to be measured by calipers to the nearest 0.1mm \$\endgroup\$ – Voltage Spike Sep 17 at 17:06
    \$\begingroup\$ The most critical dimension in this case is the height above the board. Also pay attention to the operating force. \$\endgroup\$ – Spehro Pefhany Sep 17 at 17:18
https://www.digikey.com/product-detail/en/te-connectivity-alcoswitch-switches/FSM2JELGEATR/450-2153-2-ND/2400357
My guess is its a TE connectivity part, maybe one like the one shown above.
  • \$\begingroup\$ You must be right, datasheet matches dimensions. \$\endgroup\$ – Anonymous Sep 17 at 18:03
