yes, you can use a transformer to reduce the power draw.
Assuming a nichrome heating element with a resistance of 9.6 ohms
Reducing the voltage to 96 volts will bring the power down to 960 watts at 10A
so you need a transformer that can handle 10A with a ratio 4:1 (primary and sencondary in series) or 5:1 (secondary bucking)
series droppinmg is preferred as you only need a 200VA transformer , but off the shelf parts are more common in 5:1 ratio (120V in 24V out), for that layout 240VA is needed
you could maybe use this one:
https://nz.element14.com/schneider-electric/abt7esm032b/transformer-320va-1-x-24v/dp/2070221
but replacing the inverter might be cheaper.
