8
The “Electronic Devices and Circuit Theory” book (by Boylestad, Nashelsky) gives a brief description of a random noise generator circuit at the end of “BJT AC Analysis” chapter. (Btw, exactly the same circuit appeared in the IET magazine, April 1976).
schematic diagram
DC analysis is straightforward: Q3 stage represents a 'classical' collector feedback bias. At \$V_{cc} = 21 V, \beta=100\$ we get \$A_v = 280, Z_{in} = 1.28 k\Omega\$. No surprises there. However, their description of what happens at high frequencies (where the 3 db/octave filter’s capacitors kick-in) baffles me. The exact quote from the book:
At a sufficiently high frequency all the capacitors could be replaced by short circuits, and the total resistance combination between collector and base would be reduced to about \$14.5 k\Omega\$. which would result in a very high unloaded gain of about \$731\$, more than twice that just obtained with \$R_F = 1 M\Omega\$. Because the 1/f filter is supposed to reduce the gain at high frequencies, it initially appears as though there is an error in design. However, the input impedance has dropped to about \$19.33 \Omega\$, which is a 66-fold drop from the level obtained with \$R_F = 1 M\Omega\$.
Questions:
  1. Where did they get the unloaded gain of \$731\$? Shouldn't the gain actually be reduced because of the ‘heavier’ feedback?
  2. How they get \$Z_{in} = 19.33 \Omega\$?
EDIT 1 (@analogsystemsrf):
Input impedance equation for collector feedback configuration is: \$Z_i = \dfrac{r_e}{1/\beta + R_C/(R_C + R_F)} = \dfrac{20 \Omega}{1/100 + 5.6 k\Omega/(5.6 k\Omega + 14.5 k\Omega)} = 69.3 \Omega\$
(from DC analysis: \$r_e = 20 \Omega\$, \$R_F = R4 || R5 || R6 || R7 = 14.5 k\Omega\$)
\$Z_i\$ is therefore \$69\Omega\$ and not \$18\Omega\$ as stated in the book!?
EDIT 2 (@sunnyskyguy-ee75):
DC analysis:
\$I_c * R_8 + I_b * R_4 + 0.7 V = 21 V\$
\$I_c = I_b * \beta \$
\$I_c = \dfrac{21 V - 0.7 V}{R_8 + R_4 / \beta} = \dfrac{20.3 V}{5.6 k\Omega + 1 M\Omega / 100} = 1.3 mA\$
\$r_e \cong 26 mV / I_c = 20 \Omega\$
\$A_v \cong -R_C/r_e = - 5.6 k\Omega/20\Omega = -280\$
AC at some high frequency:
\$A_v = -\dfrac{R_F}{R_C + R_F} * \dfrac{R_C}{r_e} = -\dfrac{14.5k\Omega}{5.6 k\Omega + 14.5k\Omega} * \dfrac{5.6 k\Omega}{20\Omega}=-202\$
  • \$\begingroup\$ the old Rin (1.28K ohm), scaled by (18K||100K||390K) / 1Mohm, is 19 ohms. \$\endgroup\$ Commented Sep 20, 2019 at 16:14
  • \$\begingroup\$ Show your calculations and reference to assumptions. Your understanding seems logical as Feedback ratio of Q3/R3 times its open loop gain yields higher LF gain and attenuation at HF. The poles are space and positioned high to act on the 1st octave before it becomes -6dB /octave to get -3dB /octave. \$\endgroup\$
    – D.A.S.
    Commented Sep 20, 2019 at 17:13
  • \$\begingroup\$ Av must include R3 which more effect on slope than R8 \$\endgroup\$
    – D.A.S.
    Commented Sep 21, 2019 at 17:21
  • \$\begingroup\$ I think maybe the book authors were trying to model Q3 as an opamp , hence trying to find the "open loop gain" of 731 (which as you have noted is the wrong number anyway) , and given the LF gain of the stage is ~15 , just making sure the filter stage had enough gain margin for good linearity, not sure why linearity is important in a noise source anyway. I'm sure I've seen that schematic elsewhere, perhaps these guys "lifted" it, and reverse engineering some design details.. \$\endgroup\$
    – BobT
    Commented Aug 9, 2020 at 10:16
If we simplify the source to be R2+R3 and neglect the effect of R8 for an intuitive analysis, we see the impedance ratio as the maximum voltage gain if the transistor was an Op Amp with infinite gain.
Let's assume a frequency well above all the RC breakpoints to neglect the cap impedance. This is a negative feedback (NFB) transistor amplifier where the open loop AC gain is reduced by the ratio of the Rf/Rin.
As you have computed , Rf=14.5k but Rin=R2+R3=44.6k Thus Av = -0.325 = -14.5k/44.6k or ~ 0.3
The ratio with 1M /44.6k= 22.4 but is reduced to 8.4 by the open loop gain of around 200 and collector R=5k6 of current feedback to the base.
Symbolically below. The gain values were verified by simulation for the cases of 390k open and closed below.
Graphically as follows using BODE asymptotes and the intersection being the breakpoints using an RLC Impedance Nomograph shows that the frequency response is almost half order where 1st order is 6dB/octave or 20dB/decade or a slope of 1 order of magnitude of impedance per decade of frequency.
  • \$\begingroup\$ Thank you for your detailed explanation which is 100% spot on. Although it doesn't directly answer my question (where does 731 open loop gain come from...) it confirms my assumption that the original authors messed something up. \$\endgroup\$
    – RayX
    Commented Sep 29, 2019 at 5:12
  • \$\begingroup\$ yes . Those voltage gains are impossible. I answered the better question -- the 3 db/octave filter’s capacitors kick-in) baffles me. \$\endgroup\$
    – D.A.S.
    Commented Sep 29, 2019 at 11:24
  • \$\begingroup\$ Nice answer, thanks for spending the time to run a sim and plot the results. \$\endgroup\$
    – BobT
    Commented Aug 9, 2020 at 10:18
Although I'm purely guessing here, I might found a culprit that misled the original authors.
Wrong assumption: reduced \$R_F\$ at high frequencies is seen as pure resistance by both dc and ac signals:
Resistive \$R_F\$ change \$=>\$ different transistor's Q-point (\$I_C\$) \$=>\$ different \$r_e\$ (\$26mV/I_C\$) \$=>\$ different voltage gain \$A_v\$.
(In fact, only ac signals see the changed \$R_F=14.5k\Omega\$, while the dc biasing still see \$R_F=1M\Omega\$. Therefore, the Q-point is not affected at all!).
Assuming the pure resistive \$R_F\$ at high frequencies, let's calculate the new \$A_v\$.
KVC along the feedback branch...:
\$R_C * I_C + R_F * I_B + 0.7 V (V_{BE})= 21 V (V_{CC})\$
\$I_B = I_C / \beta\$
...gives new bias current:
\$I_C = \dfrac{20.3 V}{R_C + R_F/\beta} =...\$
Here, I think, the authors mixed up resistor values (second mistake) - \$R_F (14.5 k\Omega)\$ and \$R_3 (39 k\Omega)\$:
\$...\$ (\$R_F = 14.5 k\Omega) = 3.5 mA\$ \$=>r_e=26 mV / I_C = 7.428 \Omega \$
\$...\$ (mixed up \$R_F = 39 k\Omega) = 3.39 mA\$ \$=>r_e=26 mV / I_C = 7.66 \Omega \$
Using a simplified formula for \$A_v\$ now gives:
\$A_v = -\dfrac{R_C}{r_e} = -\dfrac{5.6 k\Omega}{7.66 \Omega}\ = 731\$ (result in the book)
(Using the simplified formula is actually not appropriate as the condition \$R_F >> R_C\$ is not (fully) met.)
  • \$\begingroup\$ I'm inclined to agree with you, the crazy low values look to be Re type values. Sure for AC analyses you "short out the capacitors" , but for DC initial bias conditions you "open" the capacitors. \$\endgroup\$
    – BobT
    Commented Aug 9, 2020 at 10:03
