I found a tutorial with a schematic where you can buy a PCB for an old computer with a 6502 microprocessor.
I want to do this on my own with my own PCB (but I test the circuit on my breadboard first) and I have some questions for a better understanding of the design and this old technology (which is quite interesting).
How does the program flow work? As I understand it, I will write the program into the
28C256
EEPROM. The EEPROM is read-only (because ofWE
high) and so the EEPROM will output the program data which is stored in the address range of0x7FFF
to0xFFFF
. The address bus represents the program counter and so when the program counter increases the address increases too?Why is the NAND
U4C
connected with the main clock? If I understand it right, the SRAM of the microprocessor is mapped in the memory region from0x00
to0x7FFF
, becausea15
is connected with the ´CS`. But what is the reason to connect the clock with the NAND?The memory space
0xC000
to0xC00F
is reserved for the I/O. So the I/O is "mapped in the same region as the SRAM" and when I write to this specific address, I will write into the SRAM and the I/O controller. Is this correct?How does this microprocessor handle an interrupt? In my understanding, the microprocessor will change the address on the bus to
0xFFFE
when an event onIRQ
occurs. So I have to place my interrupt code at this specific address in the EEPROM. Is that correct?It seems that I need an EEPROM programming device to write the EEPROM. Do I have to use some kind of high voltage programming or can I use a microcontroller to write this EEPROM? Otherwise, I have to buy an EEPROM programming device.
