I'm trying to use a ball switch and an Arduino to turn on an LED. I only want the LED to turn on if the ball switch is closed for 20 seconds. Does anyone know how to do this? Thanks.
  • 4
    \$\begingroup\$ I think quite a few people know how to do this, but please be aware this site is not a free design house. You should start writing code yourself. If you're stuck, people here are happy to help assisting you doing the job. \$\endgroup\$ – Huisman Sep 21 at 19:51
    \$\begingroup\$ Can you write a timer? if timeOff >= 20 minutes, turn on LED? \$\endgroup\$ – KingDuken Sep 21 at 19:51
  • 5
    \$\begingroup\$ are you asking about programming or about circuit design? \$\endgroup\$ – jsotola Sep 21 at 19:59
I haven't tried it. But it compiles without errors. Let me know whether it works or not, please :)
#include <time.h>
const int iBallSwitchPin = 2;     // the number of the Ball Switch pin
const int ledPin =  13;      // the number of the LED pin
int iBallSwitchState = 0;         // variable for reading the Ball Switch status
int iCurrentTime = 0;     // Current time
int iElapsedTime = 0;     // Elapsed time
void setup() {
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the Ball Switch pin as an input:
  pinMode(iBallSwitchPin, INPUT);
void loop() {
  // read the state of the Ball Switch value:
  iBallSwitchState = digitalRead(iBallSwitchPin);
  // check if the Ball Switch State is HIGH:
  if (iBallSwitchState == HIGH) {
    iCurrentTime = time(NULL);
    do {
    iElapsedTime = time(NULL);
    } while ( iBallSwitchState == HIGH && (iElapsedTime - iCurrentTime) < 20);     // Checks the time for 20 seconds
      if((iElapsedTime - iCurrentTime) >= 20)
        digitalWrite(ledPin, HIGH);     // turn Led on
      else
        digitalWrite(ledPin, LOW);
    } // end if
    else {
    digitalWrite(ledPin, LOW);      // turn LED off
