A piece of lab equipment (an image intensifier) is controlled by voltage in the range of 0..5V (current is expected to be in the range of 10 mA; desired resolution is around 12 bits; no frequency requirements since we won't be changing the voltage much). The internal voltage of the intensifier is set to 500V + (850V - 500V) / 5V * Vc. I would like to make it a part of a larger apparatus, all controlled by a PC. Therefore, I need the PC to control a DAC.
What would be a simple way to do that? Should I look for a microcontroller with a real DAC (not PWM) in 5V range? (Those I found seem to be limited to 3.3V - perhaps I didn't look in the right places?) Should I buy a simpler microcontroller and a separate DAC controlled by I2C? Use a 3.3V DAC with an operational amplifier?
It is not a problem for me to write a PC or uC program, but I don't have any successful circuit building experience, so I would like to optimize for less building complexity.
  • \$\begingroup\$ Comments are not for extended discussion; this conversation has been moved to chat. Any conclusions reached should be edited back into the question and/or any answer(s). \$\endgroup\$ – Dave Tweed Sep 24 at 16:53
Here is one example of a USB to 12 bit DAC for around $80.
Typical applications include variable air damper control, blower and motor speed control, light level control, audio sound level control, motion control, water/fluid/air valve position control, variable-frequency drive (VFD) motor control, 4-20ma loop control, solenoid position control and hundreds of other applications. Connects to USB - Powered from USB port 4 channels of 10 bit Digital to Analog (1,024 increments in output level) with DAC-4U10 4 channels of 12 bit Digital to Analog (4,096 increments in output level) with DAC-4U12 Selectable reference voltage - allows for 0 to 3.3v, 0 to 5v or user supplied voltage output ranges Available with high precision voltage reference pre-installed. Allows for (0 to 1.2v), (0 to 2.048v - .5mV per increment), (0 to 2.5v), (0 to 3v) or (0 to 4.096v - 1mV per increment) output ranges
    \$\begingroup\$ We ended up buying the USB DAC. I also ordered an ATtiny85 clone pre-flashed with a USB bootloader and an I2C display to gain some experience in communicating between USB and I2C peripherals in my spare time. \$\endgroup\$ – aitap Oct 15 at 15:26
Not having much successful circuit building experience doesn't sound hugely promising but here goes for a potential solution to your problem.
If you have a microcontroller lying around already then an R2R ladder DAC with a unity gain voltage buffer at it's output would do the job for not needing to change often/quickly, being cheap and being controllable form a PC. You could just about do this with an Arduino UNO and Arduino IDE as you don't have to worry too much about how slow the digitalWrite() method is.
