Is it permissible to use a condition generated by one clock with another, fully-synchronized clock (generated by a PLL with 0 phase shift) of different frequency?
This works as expected in simulation:
`default_nettype none
`timescale 1ns/1ps
module top;
reg base_clk = 0;
reg fst_clk = 0;
reg cond = 1'b0;
reg [2:0] ctr = 3'd0;
reg some_reg = 1'b0;
always #15 base_clk = !base_clk;
always #5 fst_clk = !fst_clk;
initial begin
$dumpfile("top.vcd");
$dumpvars(0, top);
#10000 $finish;
end
always @(posedge base_clk) begin
ctr <= ctr + 1'b1;
if (ctr == 3'd5)
cond <= 1'b1;
else
cond <= 1'b0;
end
always @(posedge fst_clk) begin
if (cond)
some_reg <= 1'b1;
end
endmodule
Can I assume this will also work when synthesized (in synthesis fst_clk
would be generated by a PLL)? In my mind there shouldn't be any issues here since the clocks are synchronized and so I'm not crossing clock domains. Am I correct in thinking this? Or, have I overlooked something and I should only use a condition generated by the same clock.
