I was reading about String DACs here https://www.allaboutcircuits.com/technical-articles/voltage-mode-r2r-dacs-operation-and-characteristics/
and I saw enter image description here
Is the highlighed wrong? I mean, if just SW4 was on, shouldn't the output analog voltage be 1/2 Vref, since there are 4 resistors above SW4 and 4 below
You are correct. The author probably meant to write
For example, to produce an analog output equal to VREF/4, we only need to turn the switch sw2 on.
Note that with this circuit the output range is 0 to VREF × 7/8. You can't get VREF.
| improve this answer | |
  • \$\begingroup\$ Great! I was doubting myself for 15min. Thought there was no hope for me if I messed up a resistive divider haha. \$\endgroup\$ – AlfroJang80 Sep 24 '19 at 20:17
