So I have a M.2 to mPCIe adapter board that unfortunately I don't have any documentation for. The purpose of the board is to allow for a 4g M.2 modem to connect to a PC with a mPCIe slot.
Presumably by changing the configuration of R4/R5/R7 it's possible to set the card to use the USB, PCI, or SATA interfaces. For the life of me I can't tell what they mean by the X's and O's. Should I interpret either X or O as populated?
If it helps, this is the M2BU3S-U3D card from Bplus Tech: http://www.hwtools.net/Adapter/M2BU3.html
Those are configuration links.
  • X means don't connect.
  • 0 means 0 Ω so just bridge the pads with solder, a short piece of wire or a 0 Ω resistor.
It has been supplied configured for USB. If you confirm operation by USB that should confirm my statements above.
My interpretation here is that x is open. "O" is really a zero, implying a zero ohm jumper, or a solder bridge. The placement of R2, R5, and R7 seems like they were placed there as a user configurable option.
It's also common practice to control PCB variants through the BOM (bill of materials). It's much easier to create 1 PCB with 3 BOMs with parts that are or are not populated, versus creating 3 separate PCB designs with 3 sets of gerber files and 3 BOMs. R2, R5, R7 seem to fit this design philosophy.
