I have a ST Link V2 as pictured below. I would like to use it as a general purpose JTAG and or Serial TTL USB interface for communicating with a wide variety of devices. The documentation claims it supports SWM, which appears to be JTAG, but it's unclear if it is a vendor specific version of the standard.
Since the ST Link V2 has built-in firmware to function, I'm assuming its not just a dumb interface and may require additional steps to make it work. Can this be used for my purpose or should I just get a general purpose JTAG cable? If so, what's entailed?
ST-LINK V2
  • \$\begingroup\$ PJ answered probably, but yes you can use it with non-ST arm microcontrollers. It is more of an openocd support for that other microcontroller thing. Have had success with some and problems with others. \$\endgroup\$ – old_timer Sep 24 '19 at 21:32
  • \$\begingroup\$ I prefer a generic ftdi breakout board like the adafruit FT232H one, you can do SWD and UART. (or JTAG and UART for full sized things like the raspberry pi). \$\endgroup\$ – old_timer Sep 24 '19 at 21:33
  • \$\begingroup\$ I managed to use an arduino as a UART and it works well. It requires taking over the UART from the MCU. The mega has several UART ports to play with. I would investigate using it for JTAG, but I figured I already have the ST-LINK. \$\endgroup\$ – user148298 Oct 1 '19 at 3:21
First of all it is not an JTAG probe. It is the ARM SWD debugger probe. Probably you can use it with non STM32 ARM microcontrollers using openOCD. .
This probe does not have UART <> USB converter you of course can't use it. You need ST-LINK V2/1
