I am reading a book on nonlinear control and disturbance rejection, and in many examples, they distinguish between the "plant model" \$G_p(s)\$ and the "nominal plant model" \$G_p(s)\$. They also add that the discrepancy between these two models adds uncertainty that is lumped with disturbance. They specifically called this "unmodeled dynamics", or "modeling errors".
Nominal model was defined as the system's dynamics in the absence of modeling errors. On another hand, it was described as "the ideal model".
In another example, they provided expressions for \$G_p(s)\$ and \$G_n(s)\$.
I am very confused:
  1. Is the nominal model the desired model? (i.e. do we want to reach it?)
  2. Is the nominal model an imprecise idealization of the plant to simplify the mathematics?
  3. Do we know both \$G_p(s)\$ and \$G_n(s)\$? In the book both were provided. If we know both, then what is the point of idealization and/or modeling errors?
  4. How does it work in practice? Do implementations by researchers and engineers target \$G_p(s)\$ or \$G_n(s)\$?
I am really curious about both the theoretical and implementation side. Any insight is immensely appreciated.
In much the same way as I'd like a rich stranger to die and bequeath $100 million to me, yes, it's the desired model.
The nominal model is somewhere between your best guess of how the plant actually behaves, and a simplified model of how the plant behaves that you guess will be good enough for your purposes.
It's not possible to know exactly how a physical system will work, and in general, any physical system will have essentially infinitely complex dynamics (just count the electrons and multiply by 2...)
So you come up with a model that you hope will solve the problem at hand.
Even if by some magic you could exactly know the real plant behavior at some point, aging and environmental changes will change the behavior -- and if you're making a controller design that needs to work on multiple units, manufacturing variation adds even more variability.
Do we know both 𝐺𝑝(𝑠) and 𝐺𝑛(𝑠)? In the book both were provided. If we know both, then what is the point of idealization and/or modeling errors?
Nope. See "best guess", above.
How does it work in practice? Do implementations by researchers and engineers target 𝐺𝑝(𝑠) or 𝐺𝑛(𝑠)?
You build \$G_n(s)\$ with some notion of how much it's going to miss the mark. Then you do a robust design.
If I were writing the book, I think I'd carefully avoid the term "actual plant model" or "plant model" in favor of the term "actual plant dynamics" -- because we know the model, but we can never know the actual plant dynamics.
  • \$\begingroup\$ Cannot thank you enough. I am in awe of the comprehensive detail in this answer. Reading your answer alongside the book restored common sense. Thanks a million. \$\endgroup\$
    – ex.nihil
    Sep 25, 2019 at 0:26
By clicking β€œPost Your Answer”, you agree to our terms of service and acknowledge you have read our privacy policy.
