can i use this motor to make a cnc plottor ? is there any way to make a stepper motor using this motor?
    \$\begingroup\$ Not realistically, no \$\endgroup\$ – Chris Stratton Sep 25 '19 at 12:30
No. That is a simple motor. It cannot be changed into a stepper. To use a simple motor then you will need feedback, an encoder. You will be better off getting real stepper motors or servo motors.
