I am trying to run a mipi csi camera on a rock pi 4 but I can't figure out how to get it working. I have the rock pi 4b running on Debian (Linux) and the camera is plugged in and the power led is lit.
I have found for raspberry pi you type "sudo raspi-config" in the prompt and it opens configuration settings to enable the camera, but I can't find anything similar to work on the rock pi 4.
How can I get the camera running/taking video or pictures?
Link to camera: https://www.amazon.com/gp/product/B013JWEGJQ/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
To clarify: I am Not using a raspberry pi so raspberry pi documentation does not work. I am using a different single board computer called the Rock pi 4 https://wiki.radxa.com/Rockpi4
    \$\begingroup\$ I'd try this question on Raspberry PI.SE. \$\endgroup\$ – Ron Beyer Sep 25 at 18:59
  • \$\begingroup\$ A quick google "raspberry pi camera tutorial" gives this as the top link: projects.raspberrypi.org/en/projects/… \$\endgroup\$ – Aaron Sep 25 at 18:59
  • \$\begingroup\$ The problem is that it is a raspberry pi camera but the board I am using is not raspberry pi, it is rock pi 4. The rock pi 4 documentation says it works with the raspi camera but gives no documentation on setup \$\endgroup\$ – orange1234 Sep 25 at 19:11
