I've already known that I/O buffer transfers data on both the rising and falling edges of the clock signal.
But it really confused me why I/O bus frequency is half of effective frequency.
For example, in DDR2-800.
Basic memory clock is 200 MHz.
Use 4n-prefetch technology.
So the effective frequency equals 200MHz*4 = 800MHz from the processor (CPU)'s perspective.
Here's the point.
Since I/O buffer transfers data 800M times per second on both rising and falling edge, we can infer that, each time when it works, I/O buffer transfers 400M times on one single edge.
Thus the work frequency = 400 M times / 0.5 second = 800 MHz.
By this equation, I/O bus frequency should be equal to effective frequency, both 800 MHz.
But on Wiki page DDR its said to be 400 MHz.
DDR Table
How to explain this?
    \$\begingroup\$ I think you mean "effective frequency" rather than "efficient frequency." \$\endgroup\$
    – JRE
    Sep 26, 2019 at 10:58
  • \$\begingroup\$ Why times 4? If state changes occur on both rising and falling edge you have 2 state changes per period. So 200 MHz * 2 = 400 MHz \$\endgroup\$
    – Swedgin
    Sep 26, 2019 at 10:59
The 4N pre-fetch architecture means that 4 data words are pre-fecthed prior to the read burst from 4 different adjacent columns. This diagram assumes the row address hs already been latched by an activate command.
Here is the read timing:
DDR2 Read burst
In the actual data transfer burst, you can see DO n in the first transfer and from the datasheet
DO n = data-out from column n. where n is between 0 and 3 (the data is not necessarily transferred in the order 0, 1, 2, 3).
We ae using both edges of the clock and therefore 400 MT/s (MegaTransfers per second) equates to a 200MHz clock.
Therefore the 4N relates to the number of transfers done during a burst, not the actual burst rate.
  • \$\begingroup\$ Thank you, that's helpful.It makes sense in DDR2,where basic memory clock is 200MHz and I/O bus clock is 400MHz. While in DDR3, basic memory clock can still be 200MHz, therefore we still do 400Meg transfers per second, but I/O bus clock goes up to 800MHz. What causes the difference? \$\endgroup\$
    – miniquuu
    Sep 28, 2019 at 3:50
