Today I saw an led dimmer product. the driving circuit was like in the schematic. it was a cheap one but the circuit looks inefficient to me. when the bjt not conducting, R1 pulls the gate high, and mosfet starts conducting that's ok. but when the bjt conducting(high signal on gpio) bjt shorts the gate to gnd. thats actualy commonly used circuit. but large amount of current (12V/150 = 80mA) flows through the gnd on R1. is it okay for a commercial product?
pwm frequency is seen as 500Hz on scope. obviously when they increase the R1, rise time of the mosfet get very high and switching losses dramaticly increase. they claim that this product can handle up to 20 amps(of course there is a heatsink on mosfet).
so the question is, is there any efficient solution to drive a gate without gate driver? is it the right way to drive a mosfet?
I don't have the products document but here are bjt and mosfet.
  • \$\begingroup\$ R2 is 1k ohm that's my mistake. \$\endgroup\$
    – sinany1
    Sep 26, 2019 at 21:09
  • \$\begingroup\$ Where is this 150 ohm value coming from? You say R1 is 1k, this should have 12mA of current draw when the bjt is saturated. \$\endgroup\$ Sep 26, 2019 at 21:49
  • \$\begingroup\$ mods edited the circuit. originally R1 150 ohm R2 1k ohm sorry for mistakes. \$\endgroup\$
    – sinany1
    Sep 26, 2019 at 22:13
  • \$\begingroup\$ @Shadetheartist Yes, I edited the diagram incorrectly. Should be okay now. \$\endgroup\$
    – user103380
    Sep 26, 2019 at 22:36
    \$\begingroup\$ in the actual circuit m1 is open drain. you can connect led strip to it. they have built in current limiting resistor on them. \$\endgroup\$
    – sinany1
    Sep 27, 2019 at 6:32
For a penny or two more you can drive the MOSFET with a push-pull circuit.
In this circuit Q1 and R1 level-shift (and invert) the input to drive Q2 and Q3 which are connected as complementary emitter-followers. Peak turn on current is limited by Q3 hFE and R1, so if R1 is (say) 4.7K, the current is in the hundreds of mA.
As far as the circuit you've got, if you have a relatively high load current, however, the 150 ohms may be considered justifiable. If the MOSFET is spending most of its time 'off', however, it's perhaps wasting significant power. Keep in mind the engineer who designed it was probably more interested in keeping their job than making the circuit a little bit better- the cost of those parts might pay for his or her salary.
The transistors are called upon to do two things- to drive the relatively huge gate charge of the MOSFET and perhaps to level-shift the input if it's less than Vdd. If the dimmer output was coming directly from a chip such as LM555 runing at 12V then there would be no need of any drive circuit.
    \$\begingroup\$ pretty clear. thanks! \$\endgroup\$
    – sinany1
    Sep 26, 2019 at 21:35
Whoever designed that circuit made some newbie errors ignoring the series resistance and power dissipation of R1. — Let’s assume the LED is a strip with current limiting resistors suitable for 12V.
The input capacitance of M1 Ciss= 1470 pF and R1=130 ohms results in a power hungry current and unnecessary fast time constant =RC = 1.9us.
Considering Tau is 60% of Vcc and the range of Vgs from Ic= “off to on” is only about 15% here that further reduces the transition time.
There is a rule of thumb for cascading current buffers by current or impedance gains typ =1000 for FETs and 50 for BJT’s
Recommendation
These are commonly sold 5pc $8 online.
