6
We have an electronic lab where we test and solder. There is a computer in the room as well. I have been wondering how much of that room is really contaminated with lead. We solder, go touch the oscilloscope or spectrum analyzer, google something here and there, open up all the drawers and what not etc. In my mind if were to visually see the lead in room I always think everything would be red. I rarely touch my phone while soldering or in the electronic lab but I've recently been doing so. When I follow what I touch when then going to the bathroom to wash my hands and then to my office, I think that lead is everywhere. I'm not talking crazy amounts just that it could be there. Sometimes I touch my keys etc. etc. etc.
So when one is dealing with lead solder, how much is really being transferred to other things when one touches their phone, a doorknob, the computer mouse/keyboard etc.? Or is it such a small amount that one shouldn't necessarily worry about it?
We use 60/40 solder.
    \$\begingroup\$ Should be nothing, RoHS is final for a decade now. \$\endgroup\$
    – Jeroen3
    Sep 27, 2019 at 12:16
  • 6
    \$\begingroup\$ @Jeroen3 In some cultures, leaded solder is still heavily used for repairs and prototype work, despite RoHS, and in some, leaded solder isn't even banned. Then, there are fields with exceptions... \$\endgroup\$
    – AndrejaKo
    Sep 27, 2019 at 12:22
    \$\begingroup\$ Your skin is pretty good protection. But once inside your body, lead tends to accumulate. \$\endgroup\$
    – glen_geek
    Sep 27, 2019 at 13:21
    \$\begingroup\$ @Jeroen3 - the RoHS directive permits all equipment manufactured prior to the implementation to be repaired with SnPb solder and does not ban its use for prototypes and hobbyists. In addition, there are also industries that are exempt (aerospace for example in flight safety critical applications). Interestingly, Lead free solders (such as SAC variants) use a much more aggressive flux and requires fume extractors that are far more capable than those required for SnPb stations. \$\endgroup\$ Sep 27, 2019 at 15:47
  • \$\begingroup\$ I wash my hands after using 63/37, good enough for me. \$\endgroup\$
    – Voltage Spike
    Sep 27, 2019 at 16:31
7
This fear of lead is largely mis-guided. Yes, there have been reports of children falling ill from eating paint chips with lead in them. But this was made into a big deal because it happened to a child, whose quality of life suffered. But where are the reports of adults with lead-poisoning? Do any of those involve routes other than consuming lead? Why don't people whom are shot with lead bullets get lead poisoning?
The answer is the "consume-ability" of lead (and other metals) by the body. Half of the population has an amalgam of various metals (including mercury) in their mouths in the form of dental fillings. Mercury is extremely toxic; perhaps you've heard of the recent concern over mercury content of fish. Mercury doesn't seem to make anyone sick when it is in fillings however - but it does when eaten. And gold in fact, is even more toxic - but that is also a common tooth filling. However you can eat gold and it won't hurt you... what is going on here?
The process of eating metals is where the problem lies. In our stomachs lies very strong (hydrochloric) digestive acid. This acid breaks down most metals into a "metal salt" form, which IS absorb-able by the body. Once in the metal salt form, the trouble begins. Lead for example, is treated like calcium in the body, so it is stored in the bones.
Gold however, is not dissolve-able by hydrochloric acid, so remains inert.
There is a process to "rid" of the body of some metal contaminants, called chelation therapy. So if you know you have eaten lead, chelation will remove it from your bones. If it has been 20 years since you ate the lead however, the damage has already been done and chelation will help little.
So unless you've eaten lead, there really is no cause for concern. That said, you should be careful when eating after being near lead. Namely, wash your hands and avoid contaminating your food. Wipe down surfaces (do not use anything acidic) and consider them cleaned.
With toxic mercury in our mouths and deadly gold in our fillings, touching lead should now seem a lot less scary.
P.S. Note that modern solder is lead-free. So-called ROHS solder does not contain any lead at all. Still, eating it is a very bad idea so the same cleanliness guidelines apply. Standard 60/40 rosin-core solder is what this is referring to. Also note that acid-core lead solder, while rare today, may be potentially more hazardous due to the intrinsic acid content.
    \$\begingroup\$ I don't think you post addresses the secondary contamination brought up by the OP. I see way too many people solder, then go mess with their keyboard or phone. Then do the same while eating a sandwich the next day (although these people also don't wash their hands before eating said sandwich so secondary residues are the least of their problems). \$\endgroup\$
    – DKNguyen
    Sep 27, 2019 at 13:57
    \$\begingroup\$ @user1999 lead evaporates at wayyy higher temps than you're soldering. The fumes you see/smell are flux. In my experience, the flux used in flux core leaded solders is a lot nicer than the same in lead-free \$\endgroup\$
    – yhyrcanus
    Sep 27, 2019 at 15:09
    \$\begingroup\$ @user1999 You still don't want to breathe in the flux fumes if you can help it though. \$\endgroup\$
    – DKNguyen
    Sep 27, 2019 at 15:10
    \$\begingroup\$ There are verified reports from the 20s when a lead based fuel additive was invented by Thomas Midgely - the workers in the factory had no breathing protection and this caused severe illnesses. Lead is a neurotoxin (i.e. it affects the brain) and apparently once it is in, it will stay in. The levels of atmospheric lead in the USA prior to leaded fuel being banned was significant. \$\endgroup\$ Sep 27, 2019 at 15:55
    \$\begingroup\$ @PeterSmith That was a travesty of industry lobbying and political priorities. In the end leaded gasoline was banned because the EPA requires catalytic converters to combat smog and the lead additives messed up the catalytic converters. Not because it was a neurotoxin getting into people. \$\endgroup\$
    – DKNguyen
    Sep 27, 2019 at 15:57
If you happen to be working with older equipment, or you are trying to exhaust a supply of old solder or old components, then there may indeed be a significant amount of lead in your environment. Note that I did not say a "dangerous" amount, nor did I say a "negligible" amount.
A common problem with older homes is that lead was also used in paint, so there are lead test kits on the market that you can use to look for lead in the environment. If you are worried, I suggest that you start with one of these.
  • \$\begingroup\$ We use 60/40 solder. \$\endgroup\$
    – mikanim
    Sep 27, 2019 at 17:30
Phones are everywhere, follow you home, and are difficult to wet clean so I keep mine in a PVC phone bag meant to be waterproof and I wash it down if it gets dirty with dish soap. Also helps when working around grease and gunk and stuff.
I've heard that people who cast bullets for long periods of time end up with visible, grey, lead residue on their hands. They are working with alloys of much higher lead content (>90%). Inkless pens also use lead (real Pb, not graphite) to make their marks but I don't know what alloy that is but that does give you an idea.
The Brinell hardness, which is indicative of how easily a material is rubbed off and leave residue, of the following materials is:
  • 100% Pb is 5 BHN
  • 63/37 solder is 17 BHN
  • HB pencil lead is 14-15 BHN (obtained from bullet casters who use art/drafting pencils as gauges for the alloys they cast)
  • F pencil lead is 16-18 (obtained from bullet casters who use art/drafting pencils as gauges for the alloys they cast)
  • 6B pencil lead is supposed to be the same as pure lead, 5 BHN (obtained from bullet casters who use art/drafting pencils as gauges for the alloys they cast)
  • softwood is 1.6 BHN
  • hardwood is 2.6-7 BHN
And just for real world reference:
  • Pure Cu is 35 BHN
  • Pure Al is 15 BHN (the closest you probably see to this is aluminum foil)
  • 6061 Al is 95 BHN (the kind you probably see if it is a chunk of aluminum)
  • 6063 Al is 75 BHN (the other kind you probably see if it is a chunk of aluminum)
  • mild steel is 120 BHN
  • 18-8 stainless steel is 200 BHN (cutlery)
Plus larger particles produced from soldering which aren't as insidious because more difficult to spread
Buy a set of artist pencils and scribe them on some solder and find the pencil before and after it will no longer leave a mark on the solder. Then play around with those two pencils by lightly heading a piece of paper to get an idea of how easily the solder rubs off.
  • \$\begingroup\$ This answer would be much improved, I think, if you explained what BHN was and why it's important here. \$\endgroup\$
    – Hearth
    Sep 27, 2019 at 14:41
    \$\begingroup\$ You're using the wrong hardness measurement here. If you want to know how easily a material is rubbed off, you want Mohs (a measure of scratch hardness) rather than Brinell (a measure of indentation hardness). \$\endgroup\$
    – Mark
    Sep 27, 2019 at 21:00
  • \$\begingroup\$ @Mark That's good to know. Unfortunately, I've been unable to really find numbers of Moh's hardness for 63/37 alloy, so this is the best I can do at the moment. \$\endgroup\$
    – DKNguyen
    Sep 27, 2019 at 21:19
