Recently I've designed a PCB for the ESP8266EX-chip. With my amount of knowledge, I thought it would be smart to stitch vias into pads. To be specific, not only the ground pad of the chip, but also the small pin-pads (It's a QFN Chip).
After soldering everything using a reflow oven, the PCB wasn't working -> I couldn't upload anything to the chip. So I tried soldering the PCB in a reflow oven without any parts on the solder paste. This time I saw, that the vias suck up almost all solder off of the PCB pads. This could also be an effect because I don't have any parts on the solder paste, but after searching the internet about my problem, it seems that my open vias are the problem.
I tried filling the vias with solder paste, and then putting solder paste on the pads, no success.
Is there a way to make this work? I received 35 boards from a sponsor (couldn't go lower), and it would be incovenient if I have to throw them away.
Soldering using a solder station is not an option, I tried. Looking for a solution on the internet was also not helpful.
  • \$\begingroup\$ One thing you can try is filling the vias with epoxy and letting it cure prior to applying paste. They make epoxy specifically for this, both conductive and non-conductive. \$\endgroup\$ Sep 27, 2019 at 14:45
    \$\begingroup\$ Realistically you might fix one or two to let the surrounding work continue while you re-order boards, but if your time is worth anything, you'll want to use boards without this design flaw. Vias in the thermal pad can work even without "via in pad" processing, those in QFN perimeter pads, not - beware that even without such complexities, the perimeter pads of a QFN will do an excellent job of identifying flaws in both your design and assembly process, and they are notoriously hard to inspect as you really need to view the fillet between the chip and board from an angle, not directly above. \$\endgroup\$ Sep 27, 2019 at 15:00
To try to mitigate your problem, I would recommend filling your vias, before you place the chips, with standard wire solder and a soldering iron. Make sure you heat everything enough that the flux is all burned out of the hole.
Then, apply the paste, place the chips, and proceed as usual.
Something to be aware of: the "via-in-pad" terminology is used in two different, conflicting ways. It often causes confusion:
First, the phrase is used to describe putting a standard via in a pad (like you did). This is known to cause problems, as you found out.
The other use of the phrase is to use "via-in-pad technology" when manufacturing boards. This is a good thing, which solves the problems you are seeing. The board house will fill the holes with epoxy, then plane them flat, and then plate them. This is what you need when dealing with very-fine-pitch BGAs, for example.
This is an extra processing step done by your board house, and costs extra money. It isn't even an option at some low-price boards houses.
Another attempted solution that is often seen is that a designer will cover the drill hole with soldermask, which creates "tented vias". The idea is that it prevents solder from wicking down into the holes. Unfortunately, this doesn't work well, either.
If the via is tented on the top layer, it lifts the IC up off of the board, leaving a gap. If it is tented on the bottom layer, the vaporizing flux can cause small eruptions, like a volcano, under the chip. These can cause spacing and alignment issues.
So, in summary, VIPs shouldn't be used unless you pay for the good ones :)
To salvage the boards you have, you could try putting polyimide tape on the bottom of the board to cover the bottoms of the holes and loading extra solder past on the pads with your stencil operation (I think more gap and extra pressure and paste on the stencil).
The entire pad can be heated with a regular soldering iron and the paste should flow. In the past I have had issues with via's in pad (sometimes you use many of them for thermal relief). If that portion of the chip did not flow, then I heat up the via with a soldering iron until all the solder flows on that pad.
It's best not to use vias in pads unless you need to for thermal reasons.
