To improve isolation between the input and the other pins of the circuit, I used MCP6001R SOT-23-5 Opamp which has a pinning like this:
Footprint of SOT-23-5 Opamp
I am interested by the fact that there is quite some space around pin 4 to do guarding experiments.
However, when I designed the board I made a mistake an I thought took the "-" pin as the "+" pin.
I looked for an opamp that would have the "+"-pin on pin 4, but I could not find any.
As I really want to keep the signal input "isolated" on pin 4, I should either find the appropriate opamp or introduce an inversion in the feedback loop.
Fortunately, I know that I can't do this, but unfortunately I can't think of another simple solution: Unstable circuit due to increase in open loop gain The above schematic is for showing the principle of applying negative feedback on the "+"-pin - it does not show the OPAMP that is currently selected. Source of the schematic: Stability problem in unity-gain opAmp .
Questions:
  • Is there an Opamp out there that has the + input on pin4? Idealy in a SOT-23-5 package, but other suggestions are also welcome.
  • Or a high impédance analog follower/buffer (<1pA input current) at a reasonable cost?
  • How would I introduce a simple inversion in the feedback loop on the positive pin without breaking the stability?
It does not have to be a follower, inverting is fine too and the amplification does not have to be 1 - it can be smaller.
My input signal is a low frequency, high impedance source.
The input bias current is in the 10-100nA range. This means that the source would have to have an impedance with at least that. The LM358 does not need to be guarded, because it's input bias current does not support an application that would require a low leakage trace. enter image description here
Guards are used when the leakage through the PCB is high enough that it affects the signal, and typically is used in applications that have source impedance's below 10pA (at this point, the PCB becomes a conductor).
Edit:
This opamp will have poor results with a PH meter. Get one with the highest input bias current you can find, with the price that works for you. Single opamps in 8 pin packages usually work better for guarding as they have NC pins. Most op amps that have low input bias currents will also have pins that support guarding. Most opamps that have a low input bias current will also have layout guidelines for guarding.
More Edit: If your running a PH meter, the guard trace would look like this:
enter image description here Source: https://ww1.microchip.com/downloads/en/DeviceDoc/21733j.pdf
| improve this answer | |
  • \$\begingroup\$ Ok, sorry if the schematic confused you - I borrowed it from another question on stackoverflow. The OPAMP I selected was MCP6001R . The schematic is just showing the principle of inverting the signal so that the negative feedback is happening through the "+"-input of the opamp. The application is for measuring pH. It's not the PCB that becomes a conductor, but the "dirt" that is on it - generally the flux that is leftover from the cleaning tub that accumulates flux throughout production. Generally DIPs are used - if not leakage problems are observed. So I'm trying something else here. \$\endgroup\$ – le_top Sep 27 '19 at 21:08
  • \$\begingroup\$ The MCP6001R is good, and has layout guidelines for guarding. You should provide attribution if you ever 'borrow' something, its a good internet practice. It's also good to mention the application and what you really intend to do. I edited my question about guarding \$\endgroup\$ – Voltage Spike Sep 27 '19 at 21:15
  • \$\begingroup\$ I updated the question with information about the source of the image. The guarding recommendations are not satisfactory - the SOT-23-5 package has the right spacing, but unfortunately on the '-'-pin. And we're trying to keep the footprint as small as possible. \$\endgroup\$ – le_top Sep 27 '19 at 21:35
  • \$\begingroup\$ "we're trying to keep the footprint as small as possible" why? \$\endgroup\$ – Bruce Abbott Sep 28 '19 at 2:18
  • \$\begingroup\$ (1) We try to keep it small because of space constraints. (2) We've tried guardrings, it was not satisfactory. Currently the pH-input is aerial to avoid issues. (3) If guarding would be acceptable, it is the "+"-input that needs to be guarded, not the "-"-input . The "-" input is normally taking the feeback from the output to create an inverter or non-inverting amp (with a resistor from "-" to the reference). The guardring example from microchip is not appliable as it is as if the signal arrives on the "-"-input through anything but a PCB wire. \$\endgroup\$ – le_top Sep 28 '19 at 8:55
