I do not know how to find Vo in this circuit. According to my notes about how to take node voltage, I get
0 = Va + 6.857 V + 0V
Vo = Va
But that doesn't sound right. And I get a different answer using mesh, then using
Vo = V Across the 4k resistor
I would really appreciate the help! Thank you!
    \$\begingroup\$ Hint: one of your sources is connected directly across \$v_o\$, so nothing else in the circuit matters. \$\endgroup\$
    – The Photon
    Sep 28, 2019 at 2:21
    \$\begingroup\$ Also, you give an equation using the term \$v_a\$, but you never said what \$v_a\$ represents. If we knew that, we might be able to point out where you went wrong. \$\endgroup\$
    – The Photon
    Sep 28, 2019 at 2:22
KVL is a law, not a suggestion. Trust Kirchhoff, trust your instincts. If you are getting a different answer using mesh analysis then we should take a look at your equations.
