I'm planning to use TUHS3F05 for my ESP32 project. I'm very space limited so I need to optimize place as much as possible.
In datasheet it is recommended that TUHS* it should be used with other components yet in my testing it worked great without them (I was testing for over 10 days without any issues).
My questions are:
  1. can there be any shot or long term problems of using my schematics?
  2. why they need so many external components?
  3. are there any other so small factor AC-DC solutions?
This is recommended TUHS* schematics: Recomemnded TUHS* components
This is my schematics: My current schemantics
I've checked the instruction manuals of the part. The parts that are used in the reference schematics are:
F1 :: Input fuse
To prevent the situation when the power supply starts to draw much current, most probably because of some failures.
Eliminating this may cause damage to your parts and maybe power lines.
C1 :: Input Capacitor
To comply with conducted noise on the input and to reduce high-frequency electronic noise that may cause interference with the part.
Eliminating this may cause lots of problems in noisy lines or EMI prone environments.
Cbc :: Smoothing Capacitor
To smooth the output voltage and counter fluctuations that cause instability.
Eliminating this may cause instability on the output voltage.
R1 :: Inrush current protection resistor
To limit inrush current to avoid gradual damage to the component and avoid blowing fuses or tripping circuit breakers.
Eliminating this, well, has a risk of damage to component or blowing fuses.
SK1 :: Surge Protective Device
To protect against transient surge conditions.
Eliminating this may cause problems for the component.
So to answer your first question: Yes, eliminating those parts can cause lots of short or long term problems and drastically shorten the life of the component.
If you have to go on with your schematics, keep that in mind that, you might saw lots of instability problems, but then again it all depends on the environment.
So as advice that I've learned the hard way, always stick to the datasheet.
And if you want to check other board mount power supplies, you may check the suppliers and like digikey.
  • \$\begingroup\$ Thank you for the detailed answer. I hope I will be able to squeeze in additional components to comply with the datasheet or find some other small enough AC-DC converted. \$\endgroup\$ – david Sep 29 at 10:37
