When we manufacture certain PCBs, where 50ohms impedance matching is required the manufacturer provides a small PCB strip along with the actual PCB. What is the actual purpose of this?
  • \$\begingroup\$ Where's the photo? \$\endgroup\$ – Transistor Oct 1 '19 at 6:03
    \$\begingroup\$ To verify that the matched impedance is in fact 50 ohms. You can use a network analyzer or Time domain reflectometer (TDR) to measure the impedance. \$\endgroup\$ – Peter Karlsen Oct 1 '19 at 6:04
  • \$\begingroup\$ @PeterKarlsen Spectrum analyzer can be used? \$\endgroup\$ – MightyBeard007 Oct 1 '19 at 6:12
  • \$\begingroup\$ @PeterKarlsen I suggest you turn that into an answer. \$\endgroup\$ – Oldfart Oct 1 '19 at 6:33
I'm not quite sure about this, but it might be possible to use a spectrum analyzer with build-in tracking generator to get an idea about the impedance. The phase information will be missing thou.
