I have two CDM324 Radar motion sensors.
I want to run the two sensors close to each other.
The transmitted frequency is roughly 24 GHz and I am afraid that a small shift in one sensor transmitted frequency could enter the received path of the other sensor and it can be interpreted as a reflected signal (motion) even if there is no motion at all.
For example: the first and second sensor transmit at 24,000,100 Hz, 24,000.000 Hz, respectively. The second sensor can detect a doppler frequency of 100 Hz even if there is no motion.
I run the two sensors next to each other and I have no interference at all. Is it a chance? Could an interference happen? A false detection would be a problem for me?
