yet another noob here. answer is probably obvious for most but not for me really. Just wondering how to interpret markings on these capacitors (red circles)
enter image description here enter image description here enter image description here enter image description here
ps. first lesson learnt :)
    \$\begingroup\$ These ain't resistors, rather capacitors. \$\endgroup\$ – Marko Buršič Oct 1 '19 at 15:00
  • \$\begingroup\$ Those are capacitors, and I read 220n K which I am not familiar with so I don't know if they are 220n Farad or 220nx1000 is 220u Farad. \$\endgroup\$ – Oldfart Oct 1 '19 at 15:02
  • \$\begingroup\$ What makes you think those are resistors? \$\endgroup\$ – Hearth Oct 1 '19 at 15:02
  • \$\begingroup\$ my bad, I thought its combination of both :/ just edited \$\endgroup\$ – user3328469 Oct 1 '19 at 15:04
    \$\begingroup\$ I just noticed the line around the brown-black-brown silver resistor which means it is 100 Ohm. +/- 10% \$\endgroup\$ – Oldfart Oct 1 '19 at 15:22
Take a clue from the black silkscreen painted on the printed circuit board surface:
  • C as in C20 is some kind of capacitor. Most of those you've circled are not polarized and could be mounted either way.
  • R denotes a resistor - can be mounted either way.
  • T denotes a transistor, additional silkscreen show "E"(emitter), "B"(base), "C"(collector)
  • D denotes a diode. A silkscreen diode symbol shows which direction the cathode points.
The numbers following each letter allow multiple resistors to be uniquely identified...a schematic diagram would also show this letter followed by a number, and most often its value.
An example might be C4 220n...This is a capacitor, value 220 nanofarads. The silkscreen doesn't show the value, whereas the schematic diagram should.
There are at least two values that are printed on larger capacitors:
  • The value or size of the capcacitor, listed with a number followed by farads with units, like uF nF pF or sometimes mF. On smaller capacitors, the F is sometimes omitted.
  • The voltage rating, a number followed V. The voltage rating should not be exceeded or damage may occur.
  • Manufacturer codes (sometimes there, sometimes not) has codes for the manufacturer and can tell you what product line or even when it was manufactured.
