Can I use PWM to control the speeds of more than two motors separately in ATmega32A ?
The latest thing I could do is controlling The speeds of two mototrs using fast PWM mode in counter 1 with two compare values OCR1A & OCR1B.
  • \$\begingroup\$ What frequency are we talking about here? You could use counter 0 or 2 if 8 bits are enough? \$\endgroup\$
    – Swedgin
    Oct 2, 2019 at 9:33
  • \$\begingroup\$ 50 to 100 Hz for a 9 volt DC motor .. do you have any helpful codes or articles ? \$\endgroup\$ Oct 2, 2019 at 11:06
  • \$\begingroup\$ It's kinda hard to give some example without more information. Are the other timers in use (what does the atmega besides driving pwm), are the 2 PWM signals correlated to eachother? You should also add your existing code for driving Timer 1 \$\endgroup\$
    – Swedgin
    Oct 2, 2019 at 16:44
