I have
- DG600F coin acceptor with 12V power input and serial port output
- CP2102 usb-uart bridge and FDTI TTL-232RG cabel as an alternative
- A PC and Macbook as alternative
I need
to connect DG600F to PC by serial cable.
In the Support tips
section (in the bottom) of the DG600F product page there is the following connection scheme:
So I've connected by the following scheme:
- Red is 12V from power adapter. Connected straight to the device.
- Orange is ground from power adapter. Connected to ground from CP2102.
- Black is ground from CP2102. Connected to the device.
- Yellow is RX from CP2102. Connected to the device.
The ground connection looks like this:
What do I expect?
I put an icon into DG600F. The red diode near RX line on CP2102 should light up. I should receive some bytes on my computer using a serial port terminal. (I use serialport-terminal
from npm)
What happens
The RX diode lights up, when coin is inserted, but it lights up 5 times less brightly, then it should. It looks like it detects the signal, but it is too low. There is no input in the terminal at all.
What did I try?
- I've tried to touch RX line with my finger. There is some random input in the terminal. So CP2102 works correctly.
- In the original manual, they've used FDTI cable. So I've bought exactly the same, but the problem is the same: there is no input in the terminal. FDTI does not have any diodes, so I can not tell if it receives the signal.
- I've connected DG600F to some cheap Chinese board I have, which outputs 12V to DG600F and connects to the computer through USB as an HID. Through it everything works: coin insert is detected and the board sends the signal to PC. So I can tell, that the device itself works correctly. But I need to work with DG600F directly from the PC, because I have another payment device, which requires the same installation scheme.
- I've checked the output from 12V and ground on all connections with a multimeter. The device gets 12.26-12.27V.
- I have tried to connect RX with TX on CP2102 connectors and send a signal from terminal. It returned back. This way I can know, that the chip itself is still working.
Any ideas?
I am a software developer, not a specialist in electronics. So what I want to understand: what can be done wrong in this simple scheme:
And why I get the signal, but the diode is very dim?
