I followed this: https://learn.edwinrobotics.com/230v110v-ac-mains-detection-using-arduino-raspberry-pi-and-esp8266-thing/#Step2
With the exception that I used an LTV-814 that doesn't require a bridge rectifier.
The forwards voltage of the optos led is 1.2 (1.4max) and If = 20mA
Give: Power = I^2 * R = (0.020A)2*(390000) = 156 watts
That doesn't make much sense to me. I'm only using a 1 watt resistor so it should have blown up by now, but it doesn't even get hot. What am I missing?
Further, I calculated my own resistor value for the 390k one rather than relying on the schematic I followed in the aforementioned link:
R = (170vpeak - 1.2forwardvoltage) / .020A = 8440 ohm
Is this correct? Should I use this instead of the 390k resistor?
Mains: 120v
  • \$\begingroup\$ why are you assuming 20 mA flow through the 390 kΩ resistor? (That's pretty certainly not the case) Your calculation for the resistor value seems to make sense, why are you even using someone else's resistor value? \$\endgroup\$ Oct 4, 2019 at 7:28
  • \$\begingroup\$ What minimal current is required by the opto to operate it and what value resistor does that imply? \$\endgroup\$
    Oct 4, 2019 at 7:31
  • \$\begingroup\$ @MarcusMüller it was from the schematic of the circuit for which this was based. the opto used in that circuit had the same characteristics. \$\endgroup\$
    – Alex
    Oct 4, 2019 at 8:05
I do not know if you are connecting this to 120V or 240V ac mains, but this source voltage (U) and the resistor (R) is what defines the current through the optocoupler input LED, not the other way around!
So for example you need a current of I=20mA with a given U=120V ac mains, then you can calculate R = U/I = 120V/20mA = 6kOhms. The resistor dissipative power will be about I^2*R = 2.4 Watts (It is actually less than that because of AC current).
(I disregarded the 1.4V voltage drop of the diode as this is negligible compared to the high input voltage U).
  • \$\begingroup\$ Of course, thank you! now that you've explained it i see the err in my thinking. i am indeed using 120v power. if you wouldn't mind expanding a bit on the part that says "resistor dissipative value..."? im curious how this relates to the actual rated wattage of the resistor. \$\endgroup\$
    – Alex
    Oct 4, 2019 at 8:04
  • \$\begingroup\$ Resistor dissipative power is the actual power that is dissipated by the resistor. Of course you need a resistor with actual rated wattage higher than that (e.g. 5 watts rated resistor). \$\endgroup\$ Oct 4, 2019 at 8:24
  • \$\begingroup\$ ok, and to be clear you got the dissipative power via: 120^2/6000 = 2.4? \$\endgroup\$
    – Alex
    Oct 4, 2019 at 8:35
    \$\begingroup\$ Yes, or alternatively I^2*R = 20m^2 * 6000Ohms = 2.4V \$\endgroup\$ Oct 4, 2019 at 8:39
  • \$\begingroup\$ 2.4V should be 2.4W. \$\endgroup\$ Oct 4, 2019 at 9:59
