There is a NUD3160 relay driver on the board that I need to set ON at power-up. According to datasheet, it has internal 100k pull-down and 2V threshold voltage. So, if I add external 910k pull-up to 24V power line it should form a voltage divider sufficient to open the driver.
What bothers me though, is how reliable the datasheet is, especially in the long run. Technically, the manufacturer does not have to use these exact values, as long as the electrical characteristics remain the same.
I don't know if this question is "opinion-based" or not, but what would you recommend?
Update
After reading all the comments and answers I've come to the conclusion that relying on internal workings of the driver was a bad idea. So, here is what I am going to do:
  1. Add second resistor to get normal external divider;
  2. Adjust divider to produce around 5V gate voltage. This will ensure full opening of the driver and will reverse-bias diode so that this circuit would not load 3.3V power control signal coming from TC7PZ17 buffer (see full circuit here).
  3. Use lower values so that driver's input impedance won't matter much, but not too low to draw much current; Something like 24k + 8.2k seems to be a good compromise, wasting only 0.8mA / 0.01W per node.
Critique?
    \$\begingroup\$ It's worth noting, by the way, that this will probably not be sufficient to turn on the FET to any significant extent. The threshold voltage is the voltage at which it just barely begins to conduct, not the voltage at which it's fully on. \$\endgroup\$ – Hearth Oct 5 '19 at 21:30
  • \$\begingroup\$ You must consider the effect of the TVS in your divider , it's meant to be a weak pull for the purposes of floating pin stability. Especially when divider currents are on par with leakage, it may not be very stable with this threshold as @Hearth says. \$\endgroup\$ – crasic Oct 5 '19 at 21:51
  • 5
    \$\begingroup\$ If the datasheet doesn't specify a value for the resistor, with minimum and maximum limits, then you should not count on the resistor having a specific value. \$\endgroup\$ – Elliot Alderson Oct 5 '19 at 21:55
    \$\begingroup\$ @Maple Where does it say that? All I see is that 2V is the maximum threshold voltage, which does not mean the voltage at which it's fully on... \$\endgroup\$ – Hearth Oct 5 '19 at 22:48
    \$\begingroup\$ "threshold voltage" is a well-defined figure of merit for a FET, and it does not mean the voltage at which it's fully on. Be aware that figure 10 shows it at a drain current of 250 μA, and figure 8 is looking at a 0.8V Vds. \$\endgroup\$ – Hearth Oct 5 '19 at 23:55
13
Schematics like the one that you show should be regarded as simplified schematics - the actual implementation is likely more complex.
Anything that is not specified in the tables, graphs or text --- generally with tolerances --- is not a useable design property.
When reading the NUD3160 specification, I do find a property related to the value of the resistor, the \$I_{GSS}\$ or Gate Leakage Current: Extract from the NUD3160 specification There is also a graph showing the dependancy on the junction temperature for two voltage levels.
At 5V, nominal temperature you get 90uA, which means an effective impedance of about 55k . At 125°C, that becomes 45k. The variance is at least 10%, and the observed value is half of the 100k value shown in the schematic.
So as far I can can see, there is an indirect specification of the 100k value, and it shows that there is more to it than the schematic shows. I am not going to guess where the other half of the current flow is going.
Regarding the pull-up to enable the driver.
As your core issue is to get the driver "ON" at startup, you basically need to use this leakage current specification. The maximum rating for the Gate-Source voltage is 12V, and it is best kept close to a value not exceeding 5V. You get between 40 and 110uA at 5V. You are powering from 24V, so your target is 19V accross the pull-up resistor - so it would take a value between 170 kOhm and 475 kOhm. You do not want to exceed 10V on the gate - at that voltage with the minimum current (40uA), the resistor has to be at least 350kOhm. The actual minimum current is not specified (the table indicates "maximum current"), but the 40uA at 5V is surely below your practical usage - at 0°C it is about 47uA.
Checking the 350kOhm resistor, at 40uA, the gate voltage will be 10V (due to the resistive voltage drop). With a gate voltage of 2V, the current would be 63uA. That is just above the worst case current at 3V for a nominal temperature.
Figure 5 of the specification (the typical \$I_{GSS}\$ current versus temperature) shows that the typical current is lower. And implicitally - due to the variance in the production process - some devices can even have a lower current (just like some devices have a higher than typical current). The fact that the lower bound is not given is an issue.
As a result, with the available information, it seems impossible to ensure proper operation under all conditions with a resistor alone. The current might be lower than 40uA, which means that the gate voltage might exceed the absolute maximum rating. Increasing the resistor to lower the voltage does not ensure a high enough gate voltage at higher currents.
To conclude with a solution, it seems best to add a 5.1V zener diode across the Gate/Source, and use a 150kOhm pull-up resistor. With low currents, the zener diode ensures that the voltage remains within the maximum ratings, and with high currents, the voltage drop of the resistor is low enough to still provide 110uA.
    \$\begingroup\$ MCUs often include the pull resistance in datasheet explicitly, and the range is usually quite wide! Like you say there is likely an internal pull down plus some leakage current from other sources. But it would be non trivial to rely on this as a precise voltage divider ! However, if this is for sampling purposes, and you can tolerate gross errors (e.g. simple supply detection), it should be usable given the analysis you provided. +1 \$\endgroup\$ – crasic Oct 5 '19 at 21:49
  • \$\begingroup\$ You guessed it right, this is simplified schematics. The actual one is close to second schematics here. The most reliable solution would be to have an actual voltage divider with much smaller resistors, somewhere in 10k range, so that input impedance can be ignored. Unfortunately that will also increase power consumption, and in case of pull-up disconnected by SW1 (all boards but one master) this will create multiple pull-downs in parallel, increasing the load on enable line. That was the reason I tried to use internal R. \$\endgroup\$ – Maple Oct 5 '19 at 22:12
  • \$\begingroup\$ so from that data-sheet it looks like 60uA into a 3V load will be sufficient so for a 24V supply a 330K series resistor looks good? \$\endgroup\$ – Jasen Oct 5 '19 at 23:31
  • \$\begingroup\$ I've analysed the pull-up resistor - 330k isn't a good value. At 24V, the gate voltage would be 2V for 67uA and not guarantee that it would work for higher leakage currents. For typical devices, under typical conditions (Figure 5 of the specification), the leakage current is lower than 60uA for all temperatures, so "generally" it will work. \$\endgroup\$ – le_top Oct 6 '19 at 0:06
    \$\begingroup\$ Ok, you can also add a zener in reverse mode instead of the resistor. As long as your zener's value is between 13V and 19V you should be safe. The imprecise pull-down will pull the voltage down and only draw the current that it needs at 24V minus the zener voltage. Your voltage level is pretty much guaranteed and the current adapts to the actual "gate current". \$\endgroup\$ – le_top Oct 8 '19 at 11:58
If you can't trust the datasheet in anything it writes, get a different part. It's really as simple as that.
If the datasheet specifies the pull-down to be 100 kΩ, then the manufacturer shouldn't simply change that. It's a specified property, just like the current capability or voltage rating of that relay.
Now, ONsemi isn't "some" manufacturer, but one of the largest and most reputable power semiconductor producers in existence. They will most definitely give out a specification change document if they decide to change the part – which I doubt would ever happen; these resistors are almost certainly part of the same silicon die, and rolling a new mask, even at the gigantic structure sizes they use, is simply something that costs a lot of money.
Just make sure you buy your relays from somewhere you trust to actually get the original part.
    \$\begingroup\$ OK, that's reassuring, thanks! Buying everything from digikey, that's as close to trusted source as I can get. \$\endgroup\$ – Maple Oct 5 '19 at 20:25
  • 6
    \$\begingroup\$ I didn't see a tolerance rating for the pull-downs in the datasheet though. Can one assume a certain tolerance (e.g. 10%? or 20%?) when this is not stated? \$\endgroup\$ – Dampmaskin Oct 5 '19 at 20:29
  • \$\begingroup\$ that's a good question! I didn't pay overly special attention to that; maybe that would actually be worth asking ON \$\endgroup\$ – Marcus Müller Oct 5 '19 at 20:30
  • \$\begingroup\$ The tolerance may be given based on available pullup/down sink/source current limits. \$\endgroup\$ – MadHatter Oct 5 '19 at 20:35
  • 6
    \$\begingroup\$ I agree with Dampmaskin, tolerance is definitely a concern and I imagine they don't pay special attention to tolerances on pull-down resistors so it might be pretty poor tolerance. \$\endgroup\$ – Hearth Oct 5 '19 at 20:47
