The digital pins of two Arduinos are connected for half duplex communication:
Electrical connection
Now I want to connect the electrical connection with optical communication through a light pipe:
Optical connection
Drafts for separate input and output circuits (untested, I'm new to this):
Drafts for separate circuits
How do I make combined I/O circuits for replacing the wire? (boxes with question marks)
Notes:
  • Baud rate can be low, e.g. 100.
  • Communication really needs to go via just one digital pin per Arduino.
  • The Arduino does not have free timers left over.
  • Additional components are fine.
  • For input, the digital pin is pulled high. This is already in the existing code, which I would like to use unchanged.
  • \$\begingroup\$ <strike>Have you considered looking into IrDA transceiver modules?</strike> Never mind, I missed the half-duplex part. \$\endgroup\$ – Hearth Oct 7 '19 at 13:38
