I need to redesign an old PCB and for that I want to put down a open copper plane that won't get covered by solder mask.
I tried it by creating a rectangle in the 'Pads'-Layer. The PCBs just arrived and.. well they are covered by soldermask.
I also tried the answer to this question but now my placed rectangle is gone and I can't see it anymore.
So the question is: How do I create a copper plane without soldermask?
Soldermask is layer 29 and 30 (tStop/bStop). Anything on those layers is not covered with soldermask.
Draw a polygon or shape on those layers.
Your current visible layerset might not show these layers.
Type: display and press enter or click the layers button to make them visible.
  • \$\begingroup\$ This solved it. I am now seeing it again. Thank you! \$\endgroup\$ Oct 7, 2019 at 9:49
