Quoting from Wikipedia
Switching converters (such as buck converters) provide much greater
power efficiency as DC-to-DC converters than linear regulators, which
are simpler circuits that lower voltages by dissipating power as heat,
but do not step up output current. Buck converters can be highly
efficient (often higher than 90%)
Most converter designs will be optimised to be at their most efficient around their maximum rated output. So, for example, if the output were 9W and the efficiency 90% you would need 10W input. As you have a number of converters you need to calculate the maximum required input power of each from their specified efficiency and load. Sum these and that is the maximum power the battery will need to supply.
For example, if you have a battery supply of 12V and 3 converters each with an output of 10 W but with peak efficiencies of 70%, 80% and 90% they would require 10/0.7 + 10/0.9 + 10/0.9 = 38W (rounded) so your battery would have to be able to supply 38W or about 3.2A assuming all 3 converters were on full load at the same time.
If by "Using a power transistor in series [with] the battery ... " you mean as a linear regulator the efficiency will be worse. All it can do is dissipate the excess power in the form of heat.
Taking the above example again and say that the 3 DC outputs required are 3.3V, 4V and 5V all at 10W each then the total current draw will now be 10/3.3 + 10/4 + 10/5 = 7.5A . The battery would have to supply this current in full or 12 X 7.5 = 90W for a useful 30W output. 2/3 of your power would be wasted as heat.
Whether using a buck converter or a linear regulator the power required from the battery will be roughly proportional to the load. The efficiency of converters tends to drop off with part load so there will be a proportionally larger power draw from the battery.
I see in a comment you have changed "power transistor" to "power resistor". This is even worse as not only do you still have to dissipate the power, but you've lost any regulation.
