Would it be safe to replace a ferrite bead that had a rating of 47 ohm @ 100MHz 5A with one that is 70 Ohms @ 100MHz 6A?
I can't seem to find an exact replacement.
https://www.amigawiki.org/dnl/schematics/A4000_Rb.pdf - fb177 for example.
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityWould it be safe to replace a ferrite bead that had a rating of 47 ohm @ 100MHz 5A with one that is 70 Ohms @ 100MHz 6A?
Sure you can, IMO the second is even better choice since it has a higher impedance at rated frequency, which means it will attenuate more radio interference that it will catch in external IO wires acting like antenna. At the same time it can pass more DC current 6A vs 5A, it will have lower impedance at DC.
Looks like a good choice to absorb some emissions for +5V user external use as long as you use twisted pair wires and a low ESR user load cap to regulate the load transients.
