What would be a simple way to convert RS-232 +/-12 V digital levels into +5/0 V respectively?
  1. I considered an optocouple, but I can't find one that can withstand -12 V reverse voltage. I considered adding a two-resistor voltage divider, but I suspect that will worsen the slew rate of the device, and I have no idea if that will be enough to become a problem (I'm aiming at the switching speed of 19 200 baud).
  2. There's this simple answer, but it requires a transistor that can withstand +/-12 V as well - I'm looking for one right now but haven't found a suitable part yet. I'm also slightly worried about not having galvanic decoupling.
  3. I considered a 5 V linear stabilizer, but I suspect it may not be fast enough to turn off/on, after all, they weren't designed for this task.
Perhaps, an optocouple with a bulky diode in series capable of withstanding -12 V?
    \$\begingroup\$ EIA RS232 accepts both levels. Why convert? \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Oct 8 '19 at 17:32
  • \$\begingroup\$ @SunnyskyguyEE75, I have not seen that mentioned anywhere yet. Can this be expected of a personal computer's COM port? \$\endgroup\$ – Violet Giraffe Oct 8 '19 at 17:42
  • \$\begingroup\$ Yes because the Rx accepts any level in this range even down to +/-3V \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Oct 8 '19 at 17:43
  • \$\begingroup\$ @SunnyskyguyEE75: fair point, thank you, very useful info indeed! \$\endgroup\$ – Violet Giraffe Oct 8 '19 at 17:44
  • \$\begingroup\$ @SunnyskyguyEE75: But wait, where am I going to get -3 V out of a +5 V device? \$\endgroup\$ – Violet Giraffe Oct 8 '19 at 17:45
Why not a MAX232? Purpose designed for exactly this application.
https://en.wikipedia.org/wiki/MAX232
  • \$\begingroup\$ Hm, it didn't occur to me. Requires quite a few capacitors, but otherwise seems very simple to use and the price is low enough. \$\endgroup\$ – Violet Giraffe Oct 8 '19 at 17:33
    \$\begingroup\$ Also any other 5V powered RS232 receiver (or tranceiver) will do, and compatible clones of MAX232 tend to be cheaper. MAX232A and clones work with smaller capacitors than non-A version if it matters. \$\endgroup\$ – Justme Oct 8 '19 at 17:51
