I'm currently looking through a part catalog from a motor manufacturer and notice that you can purchase this motor with different motor winding types. Specifically, you can order the motor coil wound either delta or wye configured.
Why would a manufacturer offer multiple winding type? What are the pros and cons for each style?
A spec sheet link and actual component IDs would be very useful.
Presumably these are BLDC motors.
Compared to the other configuration:
  • Wye configuration
    • Needs higher voltage
    • Requires more cells.
    • Requires lower current so lower I^2 R losses, lower spec cells, lower current FET needed.
  • Delta configuration
    • Requires lower voltage
    • Requires fewer cells
    • Draws more current
When optimising a design the above factors may affect design cost.
Real world example:
I'm looking at a design that pushes current LiIon cells to their limit power wise.
Energy wise I could built the packs I need with 18650 cells.
But the top 21700 cells allow higher power per cell.
So, to achieve the same power levels with 1850 cells I need more cells and so higher voltage.
In my case, to minimise costs, current volume pricings mean that fewer 21700 cells at lower prices overall cost less than more 18650 cells. In this case, unusually, the available energy is not important - 18650 or 21700 will both meet the needs once power requirements are met.
SO in my case a Delta wound motor with lower voltage and higher current will make sense.
Given other requirements, the opposite may apply.
