Hi I have upgraded EAGLE to 9.5 and have one quite serious issue. The VIAS are displayed smaller than in the actual gerber file or manufacturing preview. Do you know the option which will force Eagle to display them the same way? I did not have this problem in the 7.5 version
enter image description here enter image description here enter image description here enter image description here
EDIT
As in the @ThePhoton answer, it is the soldermask stop area. It has confused me. enter image description here
  • \$\begingroup\$ Is the preview using the drill or the finalized hole size? (which is smaller than drill) \$\endgroup\$ – Jeroen3 Oct 13 at 20:12
  • \$\begingroup\$ @Jeroen3 yes - it is preview if the complete gerber file set. I am using zofzpcb.com viewer \$\endgroup\$ – P__J__ Oct 13 at 21:25
What you're seeing in the on screen view is the copper pad associated with the via. Even though it is completely flooded with the surrounding copper fill, the tool is still keeping track of that pad and displaying it in the editor.
In the finished board view, you're seeing the solder mask openings of the two vias are overlapping.
If you want to see that in the design view, you can probably turn on the solder mask layer visibility in that view. (But I don't use Eagle, so I can't tell you the exact steps to do that). Normally you'll want to see the solder mask layer in the designer in the final stages of the design process to be sure your silkscreen features are all over solder mask.
  • \$\begingroup\$ 100% correct answer. Thank you very much :) \$\endgroup\$ – P__J__ Oct 13 at 21:28
