I've recently bought a 9 V, 3 W solar panel that I wanted to use to make a small project in my balcony, then I bought a 6 V, 4000 mAh sealed lead acid battery, I want the solar panel to always charge the battery through a PWM solar charger whenever possible.
I am a beginner in electronics, because I am just still young, in highschool, but electronics is my no 1 hobby and I need someone to answer my question.
My question is very simple, after dividing watt by voltage, I will get a maximum current of the solar panel which is around 300 mA, ironically I think in my area I would get just 100 mAh, but anyway I've recently read about how to charge a lead acid battery and there is a statement I read before, that a lead acid battery is charged at current of 30% of it's capacity if I applied this rule to my 4000 mAh battery I would need a 1.2 amp to charge it in (2.4 volts per cell), is this a must or any current less than 1.2 amp can charge a lead acid battery?
