10GBASE-R using 64b/66b encoding scheme (3% overhead) 10GBASE-X using 8b/10b encoding scheme (20% overhead)
10GBASE-R is achieved with single xcvr lane 10GBASE-X is achieved with 4 XAUI xcvr lanes & 2 RXAUI lanes.
Looking at the advantages 10GBASE-R having today, is 10GBASE-X is still being used in today Ethernet world? Or it is just a legacy protocol?
| improve this question | | | | |
    \$\begingroup\$ Just from the encoding schemes, I would assume that 10GBASE-R is less fault-tolerant than 10GBASE-X, since the more bits you have in your line code the more error detection and error correction you can do. But I don't have much background in these things, so I could be wrong. \$\endgroup\$ – Hearth Oct 15 '19 at 13:18
  • \$\begingroup\$ Is it still being used today? Not a valid EE question. \$\endgroup\$ – Andy aka Oct 15 '19 at 13:20
    \$\begingroup\$ This type of encoding is not FEC, it does not correct bit errors. \$\endgroup\$ – alex.forencich Oct 15 '19 at 20:25
10GBASE-X is essentially obsolete. Four times the pins, four times the fibers or wavelengths, four times the traces, larger transceivers, etc. vs. 10GBASE-R. And no advantage besides lower per-lane bandwidth.
Now, there will be legacy hardware running this protocol, but only because nobody has bothered to replace it with something more modern.
| improve this answer | | | | |
