(This is not a homework question.)
While reading "Digital Computer Electronics" by Albert P. Malvino, I found this circuit on page 121, figure 8-22(a). It claims to be an example of a discrete TTL tri-state buffer, but I believe it to be wrong.
Best I can tell, the output will always be either high or tristated: it will never be low. I also simulated it online, and the results agreed with this assessment. I googled for published errata, but found none.
Would people say this circuit was in error, or am I missing something crucial?
photograph of textbook
  • \$\begingroup\$ It won't work for driving TTL. Connect it to a TTL input. It cannot sink the required negative 2mA. It would only work with mos input, and then only if a pulldown resistor was added to Dout. (TTL inputs have no such pulldown resistor!) \$\endgroup\$
    – wbeaty
    Oct 16 '19 at 1:22
  • \$\begingroup\$ It won't work for driving CMOS either. Or anything with any sort of pullup. \$\endgroup\$
    – Finbarr
    Oct 16 '19 at 9:58
For true TTL tri-state operation the output must be able to pull up and down. The circuit in your book can only pull up, which is not compatible with TTL logic.
Here is a real tri-state TTL (inverting) buffer:-
When Enable is high Q3 is turned on, which turns off Q5 via D1, and Q4 and Q6 via Q1B. Q6 provides the essential pull down when not tri-stated.
  • \$\begingroup\$ This is pretty much what I figured. Without a pull-down, there are only two states. It's essentially the opposite of an open-collector gate. So the author is wrong, and the other answerers of this question are wrong. \$\endgroup\$ Oct 16 '19 at 21:10
  • \$\begingroup\$ It doesn’t actually say that it is TTL logic compatible anywhere in the text. \$\endgroup\$
    – metacollin
    Oct 18 '19 at 15:32
  • \$\begingroup\$ @metacollin the OP says that it does. 7400 gates are mentioned in a later paragraph, but the text is cut off in the photo so its relevance can't be verified. That is why I was careful to not state that the textbook was wrong. In any case it's a poor example. Why talk about tri-state TTL right after showing a dodgy circuit that isn't TTL compatible? \$\endgroup\$ Oct 18 '19 at 18:45
Upon finding the original textbook online and reviewing the wording, my previous answer was incorrect so, I reversed my opinion. Apologies for the Senior's moment.
This is NOT a 3 state switch. The text is incorrect.
There is no active open collector to pull down the bus to 0V < 100 ohms for a logic "0" or even 10k for high Zin.
