I am confused about the maximum current limit of this DC Motor. Rated Power is given as 220W and Rate voltage is given as 24VDC. According to this maximum current should be 9.166A. But 2.5Amax is also mentioned on the name plate. So what should I consider as the maximum current limit so as to design the protection circuit for this motor? Motor Nameplate
  • \$\begingroup\$ Please provide a link to the motor's datasheet. \$\endgroup\$
    Oct 16, 2019 at 7:44
  • \$\begingroup\$ Is it a stepper motor? \$\endgroup\$
    – user16324
    Oct 16, 2019 at 7:50
  • \$\begingroup\$ Does it have a brake? Some data could be related to the brake. \$\endgroup\$ Oct 16, 2019 at 8:04
  • \$\begingroup\$ Remember to take the stall current into account aswell \$\endgroup\$
    – Sorenp
    Oct 16, 2019 at 13:09
    \$\begingroup\$ Why are you shouting at everyone? \$\endgroup\$
    – Transistor
    Aug 2, 2020 at 22:12
No, a rated unit \$ \neq \$ a maximum unit.
So, if the rated power is 220W and the rated voltage is 24Vdc, then the rated current should be 9.17A.
By definition the rated current \$ \leq \$ maximum allowed current.
So, the shown specs are weird.
Looking up a few other motors from MOTION TECH MOTORS show the same remarkable data:
For all these motors, the output power is more than the (electrical) input power, which is, of course, nonsense. It would make more sense when when the output would be a factor ten less.
But then, motors with the same input voltage and current having a higher RATIO also have a higher output power, which little sense either. A higher reduction ratio would give an equal (same number of gear stages) or lower efficiency (more gear stages).
So, I fail to see any logic here.
In the linked datasheet the MOTOR specs show the max current, so, (for what the specs are worth) I'd go for 2.5 A (max).
But I'd rather recommend using/finding a motor with decent/plausible specs.
