my question is how you can convert the bloc diagram which have a disturbance input to a state space representation and how you can calculate the controllability matrix then
if you can give me any textbook that explains that i googled it a lot but i guess i dont have the right vocabulary because i couldn't find anything
the system of issue : Mx is the disturbance
It is basic block diagram algebra.
First, you write out the algebraic equations and solve for the unknowns \$x1\$ and \$x2\$.
$$\text{x1}=\frac{0.05 (\text{Ua}-0.1 \text{x2})}{0.01 s+1}$$ $$\text{x2}=\frac{-\text{Mx}+\text{x1}-2 Y}{0.5 s+1}$$
Next you write the output equation as \$Y= \frac{1}{s} x2\$ and solve for \$Y\$ in terms of the two inputs \$Ua\$ and \$Mx\$. This will give you the transfer function model from the two inputs to the output \$Y\$.
Then obtain a state-space realization.
Since \$Mx\$ is a disturbance, you want to remove the column of the input matrix that corresponds to that before computing the controllability matrix.
  • \$\begingroup\$ thank you so much \$\endgroup\$
    – zed_eln
    Commented Oct 16, 2019 at 18:47
